will 94-01 greddy turbo ls kit bolt on my 2000 gsr
Old May 21, 2005 | 09:19 PM
  #51
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by greengsr2k
shmoo i already have slim fan on the ac side. do you think i need one for passenger side
The A/C condensor fan doesn't need to be modified in any way. It is the radiator fan that you need to worry about. So, yes, I do think you need one for the passenger side. You can try to modify the one you have now, but I would be safe and save yourself the hassle and order a slim one just in case.
where does ac line get bent?? Does it get bent down or forward to left more
It gets bent toward the radiator fan. In its normal spot, it interferes with the wastegate, so you need to bend it away from it so it clears the wastegate and the radiator fan.
Old May 21, 2005 | 09:26 PM
  #52
Provocateur
On permanent hiatus
Here is the pic of my car and the routing for the lines:
Red - wastegate vacuum line
Blue - oil feed line
Yellow - Upper AC line
File Type: jpg
Old May 21, 2005 | 09:38 PM
  #53
greengsr2k's Avatar
greengsr2k
i went ahead and ordered me a slim fan for the the radiator side just in case. Thanks for the excellent diagram schmoo. So shmoo you were able to keep your stock fan on the driver side??? No trimming needed. How much clearance you have driver side from hitting the manifold???
Old May 21, 2005 | 10:18 PM
  #54
Provocateur
On permanent hiatus
I am still running the stock radiator and stock fans, so I don't really have a clearance issue.
I have about 1 inch of clearance all the way down between the AC fan and the manifold. Since you have a slim fan, it will be fine.
Old May 21, 2005 | 10:28 PM
  #55
greengsr2k's Avatar
greengsr2k
Can you see the slim fan on my ac side ??? BTW i am getting my gsr tuned with Crome Pro which is comparable to hondata and just as good.
Old May 21, 2005 | 10:29 PM
  #56
greengsr2k's Avatar
greengsr2k
Yes shmoo. i do have a conversion harness. i will use the p28 chipped ecu to drive to the dyno instead of that blue box.
Old May 21, 2005 | 10:50 PM
  #57
greengsr2k's Avatar
greengsr2k
do you have boost contorller shmoo. Do i really need that and all those gauges if i wanna boost stock??
Old May 21, 2005 | 11:11 PM
  #58
greengsr2k's Avatar
greengsr2k
i also have a integra type r throttle body. The charge pipe should bolt on right even the itr is 62mm
Old May 21, 2005 | 11:43 PM
  #59
Provocateur
On permanent hiatus
Let me know about the details of that. The slim fan will most likely work. You may need to modify the radiator bracket so the radiator can slide back a little for maximum clearance.
OK. I would recommend being on the safe side and getting it towed over.
No. Gauges are nice but not necessary. A boost controller isn't necessary unless you plan on boosting more than the Greddy preset 7.8 psi.
You may have to modify a coupling to get it to fit, but it should be in the right position to attach to the throttle body.
Old May 22, 2005 | 06:01 AM
  #60
greengsr2k's Avatar
greengsr2k
what do you mean modify a coupliing???
