Smoke from valve cover!!!!!!
Old Apr 30, 2005 | 10:42 PM
honura's Avatar
honura
Seni
Default Smoke from valve cover!!!!!!
Ok I am getting a little presurized smoke and steam(i guess) comeing from the hose on the rear of my 95 ls motor. What can this be? If I plug the hose with my finger it does not feel hot or anything but when I let it go it feels like it released all the pressure I just held back. Thanks for the help guys.
Old May 1, 2005 | 07:03 AM
escrayzee's Avatar
escrayzee
...ya 'cause there's only 1 hose on the back or your engine right?
are you talking about the "breather" hose that goes from your valve cover to your intake?
Old May 1, 2005 | 07:39 AM
honura's Avatar
honura
Seni
Yeah
Old May 1, 2005 | 12:25 PM
escrayzee's Avatar
escrayzee
well........isn't the hose connected? is the steam (or whatever it is) coming out even though the hose is connected?
Old May 1, 2005 | 01:57 PM
DaBatThrower's Avatar
DaBatThrower
yah, from what it sounds like... wouldn't the simple solution just be to replace the hose?? Maybe if you could try explaining in a little more detail??
-DaBat
Old May 1, 2005 | 04:21 PM
honura's Avatar
honura
Seni
Well no the hose is disconnected! Cause of my intake. I noticed that it was doing that. The smoke-steam is white. Also When I step on the gas you can see it shot out a whole lot more. And where the hose hits the intake there is a bit of oil there.
Old May 1, 2005 | 07:01 PM
DaBatThrower
is this the pcv valve hose that dumps back into the intake manifold from on top of the valve cover?
Old May 1, 2005 | 07:54 PM
escrayzee's Avatar
escrayzee
i think he's refering to the hose that goes from the valve cover to the intake tube before the TB. The area where some people put a little breather on.
Old May 2, 2005 | 04:31 AM
honura's Avatar
honura
Seni
this is what im talking about.
File Type: jpg
Old May 2, 2005 | 12:28 PM
escrayzee's Avatar
escrayzee
...ya man....that's what i thought it was. Where's the rubber hose? There should be a hose from the nipple on the valve cover going to your air intake. If you don't have the hose then you can easily get one and you should be set.
