Suspensioln!?!?!
Old Apr 27, 2005 | 06:43 PM
tsizzle99's Avatar
tsizzle99
Default Suspensioln!?!?!
wuttup fellaz...i was gonna purchase some lowering springs...i was wondering what you guys reccomended...i was looking for the best performance and lowering quite a bit...maybe like 2.0...?
i was currently looking at the
sprint (2.5/2.0 and the 3.25/3.0)
eibach (dunno which one)
tien stech .....
lemme know what you guys think...or if you have any suggestions that will lower it and help with performance thanx!!
tsizzle
Old Apr 27, 2005 | 06:46 PM
jay12187's Avatar
jay12187
I have a set of Eibach Sportlines on my 94 RS and I love them. It gives the car a nicer stance and it looks so much better than stock. I have had absolutely no problems with them at all and have been extremely pleased.
Old Apr 27, 2005 | 06:57 PM
tsizzle99's Avatar
tsizzle99
yea i heard eibach are really nice...if anyone has pics...i wuld love to see...:-)
Old Apr 27, 2005 | 07:06 PM
Importbuyer's Avatar
Importbuyer
Want to buy a lude
Default coilovers
Coilovers have been given such a bad name,and thats because most ppl buy those cheap ebay coilovers. Springs are nice,but you have no adjustability.
There are some very nice coilovers out there,and regardless of the height you set it up for,they will have the same dampening characteristics...
Before you buy any thing to lower your car,you need to look into aftermarket shocks.Tegs have shocks all around the car,no struts...
I think adustable shocks are the way to go,and with coilovers(especially the good ones,with extra adjustment features) you CANT be disappointed.
Ive learned the hard way that its much better to spend the xtra coupla bucks now,and get what you actually want,than wish you had later.
Shocks are a must before you lower it though.The stock shocks will definitely go very soon after lowering it.
Also,lowering it will give your wheels more negative camber...bad for tire wear...you can adjust the rear by putting washer inbetween a bolt that connects to the undercarriage,and worse that can happen,you may need a longer bolt.
The front end on the other hand needs a kit to make the camber adjustable enough to bring your camber back to tolerable levels. Last i checked it costs around 200 bucks...thats somthing i need,and i would prolly have saved myself a few hundred dollars in tire wear had i actually gotten them(17 inch tires,of decent quality usually sell for around 125 each,or more with oil prices going up)
I have 5 way adjustable tokico illuminas all around my car,with a semi decent set of coilovers with height adjustment only,and im quite happy with the performance...
Somthing to think about,and sorry for so many words!
Old Apr 27, 2005 | 07:43 PM
if ur lookin for 2 inch drop i do believe ur not gonna want eibachs i think they only make a 1.3 drop on the teg...but i could be mistaken
Old Apr 27, 2005 | 08:09 PM
tsizzle99's Avatar
tsizzle99
do you guys think i should get shocks? or springs....dont have a LOT of money
Old Apr 27, 2005 | 09:00 PM
Schwa's Avatar
Schwa
Schiggity
What's the lowest one can go without needing a camber kit?
Old Apr 27, 2005 | 09:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Depends on whether the alignment shop finds it out of spec after lowering or not. It is not a solid number since it is different with every car and every drop.
Old Apr 27, 2005 | 09:29 PM
Provocateur
On permanent hiatus
To answer the original question, the best ride quality and drop for the money is a set of Neuspeed Race Springs (2.0 F, 1.75 R) coupled with a set of either KYB GR-2 (non-adjustable) or KYB AGX (4 way adjustable) shocks.
Coilovers are much too stiff for my taste. I would rather have a smoother ride than adjustability of ride height. But hey, you can do what you want with the car.
Old Apr 27, 2005 | 11:13 PM
Schwa's Avatar
Schwa
Schiggity
Swell. I agree with the adjustment thing, not really neccessary for a street application. Shmoo is that what you are running right now?
