Scary squeaking noise
On permanent hiatus
I fired up my car today and I noticed a faint squeaking noise coming from the engine bay. I have tried all day to try and find the problem and I have pinpointed where the noise is coming from.
I got underneath the car and it sounds like it is coming from the oil pan/flywheel cover area. It is a faint but noticable squeak and it really concerns me because of where it is coming from. It sounds a lot like a squeaky belt but all the belts are tightened to spec and the noise isn't coming from there. There doesn't seem to be a loss of power at all, just an annoying squeak. Does anyone know what could be the problem or how I could pinpoint the problem?
On permanent hiatus
About 8 months ago. It isn't the belts as I have checked the tension and the noise isn't coming from where the belts are. It is coming from the oilpan and flywheel cover.
Throwout bearing lubed? Does it do it in gear, or in neutral? Does the noise change with revs?
On permanent hiatus
I know this isn't even comparable but with my 94 S10 (5 speed) in neutral there's a rattling/squeeking noise....i know it's the release bearing goin but i've driven it like that for like 2 years and nothing has happend yet.....mind you i've taken it easy on it. Either way, i'm guessing it's a bearing...Just keep monitoring it as time goes on.....it shouldn't be a life or death situation right now but just keep listening for anything getting worse.
On permanent hiatus
Originally Posted by civicandtegra
do u cold start your car alot
Spun rod bearings don't squeak, they produce rod knock..a low pitched metal on metal knocking noise coming from the block. I think its the throwout bearing.
On permanent hiatus
