Problem with cylinder #4?
Old Apr 18, 2005 | 08:02 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
Default Problem with cylinder #4?
Switched from Bosch Platinum +4 today to ngk plug and found this on cylinder 4...all the others were good....shitty plugs or wires? its also white on the end so im wondering if im buring oil/coolant?
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 18, 2005 | 08:31 PM
honura's Avatar
honura
Seni
your rings might be bad. Good thing you got the ngk those dahm 4 platn suck balls
Old Apr 19, 2005 | 06:14 AM
carta79's Avatar
carta79
Life after death
Was the check engine light on? I've never had any issues with Bosch platinum plugs. How many miles on your car and those spark plugs?
The ignition wires look hurt, you should have purchased some NGK ignition wires in the process. Also that breather element filter on your valve cover is useless.
Old Apr 19, 2005 | 09:29 AM
Hondaman's Avatar
Hondaman
Black Pearl
It looks like the spark plug hole got water in it from the top. I doubt you are burning coolant and it's getting on the top of the plug, that just doesn't make much sense. :thinking:
My guess is that your boot that covers the hole for spark plug 4 leaks water and when it rains or you wash your engine bay, it got in from there. Or it may be from condensation.
Old Apr 19, 2005 | 01:22 PM
aboobybobpleez
plugs and wires arent that old..maybe on the car for about 5-6 months and about 4000 mi. if that. check engine light is on and throwing code 65 which is "Secondary oxygen sensor heater" ??????????
Old Apr 19, 2005 | 01:30 PM
94civicEX's Avatar
94civicEX
I got worms.
Seems like you just got water in it. Looks like you have aftermarket plug wires which don't fully seal around the top.
65 is your Secondary O2 Sensor located on top of your catalytic convertor.
99 Integra GSR
06 TSX
duck squad member #00003
Old Apr 20, 2005 | 05:19 AM
carta79's Avatar
carta79
Life after death
Yup, what kind of wires are those. I would ditch them for some NGK wires along with the filter on the valve cover.
Code 65 is an open/short in the secondary sensor heater circuit. You could try and measure the voltage at the sensor connector to make sure it's within spec. If the sensor checks out then there could possibly be a short at the ECU/ECM.
Or substitute a known good sensor to make sure that's the problem before you go out and buy one. Most likely the sensor in the cat has crapped the bed.
