vtec head?¿?¿?
Old Apr 13, 2005 | 05:54 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
'Better' is a questionable term. It's hard to say cause I haven't seen a direct comparison between an LS and an LS/VTEC. If you're going to boost, I wouldn't waste the money getting all the parts and everything to do the LS/VTEC. The LS motor is very nice for boost and would work well on its own. Spend your money boosting the LS.
Old Apr 15, 2005 | 06:13 PM
integra333's Avatar
integra333
if i were to put a type r head on my block what would i have to do im trying to make a fast n/a
Old Apr 15, 2005 | 07:47 PM
teg92's Avatar
teg92
WHAT OK YEAH!
You should at least Improve the block a little bit.
Old Apr 16, 2005 | 10:49 AM
integra333's Avatar
integra333
how should i go about doing that. i want to run 12:1 compression and be able to red at 9000 if posible
Old Apr 16, 2005 | 02:53 PM
integra333's Avatar
integra333
what all would i have to do to convert ls/vtec, but by putting a type-r head on it help me out please!
Old Apr 16, 2005 | 02:57 PM
Snoopy's Avatar
Snoopy
been there done that
http://www.importreview.com/reviews/lsvtec.html
you want to strengthen the bottom end? forged internals, main girdle, everything balanced.
you want to rev to 9k? stiffer valvesprings, titanium retainers, and cams that make power that high.
Old Apr 16, 2005 | 07:10 PM
integra333's Avatar
integra333
[QUOTE=:snoopy:]http://www.importreview.com/reviews/lsvtec.html
so it will run me around 9 grand¿ what would u say about putting a b16a gen2 in my in teg, what would i have to do to make that motor rip, or should i just get a gsr and transplant it in?
Old Apr 16, 2005 | 07:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The B16 won't have enough torque for the Integra chassis.
Why don't you just boost it? Boost > VTEC. I never understood the point of a N/A setup on an LS motor considering the compression is better suited for turbo. If you want N/A, I suggest you start with a motor already made for the higher RPMs, the B18C.
