Beginning Tuner help
Old Apr 12, 2005 | 12:06 PM
Snoopy's Avatar
Snoopy
been there done that
Originally Posted by Exadar
why the icebox instead of say an AEM long ram or V2 with a bypass valve? I thought air boxes sucked
all intakes suck....in air.. :chuckles:
depends on you if you want to spend $300 or $30 for a filter on a stock
Old Apr 12, 2005 | 12:09 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
Well duh.... :-P i just thought that long rams and such were better than a box intake. Is the only advandage to the icebox the fact that you don't need a bypass valve?
Old Apr 12, 2005 | 12:10 PM
carta79's Avatar
carta79
Life after death
Why the Apexi ws? It has a chambered exhaust design which hinders performance. I mean why swap a stock chambered exhaust for a aftermarket chambered exhaust.
The complete Comptech intake setup will blow any AEM intake off the charts. You can quote me on that. AEM V2 is a crock of crap.
It's called a cold air intake, saying long ram sounds funny.
Old Apr 12, 2005 | 12:11 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
i really like the sound of the WS and i'm goin for a sleeper look. the comptech sounded really nice, but got too buzzy for me at higher rpms
Old Apr 13, 2005 | 10:50 AM
DiAbLo3785's Avatar
DiAbLo3785
Working on project CRX Si
:goodjob:
Old Apr 13, 2005 | 12:31 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
Carta and Diablo, i know you can help me on this one. I'm assuming the big advantage the the icebox has over the AEM CAI w/ bypass is the fact that i'll get maximum HP gains w/out the risk of sucking in water right?
Old Apr 13, 2005 | 01:34 PM
carta79's Avatar
carta79
Life after death
Yes you're correct, also I would imagine that a bypass valve would somewhat decrease the power output of a cold air intake. Incoming air most likely gets disrupted as it passes that valve on its way to the throttle body.
If I only had a penny for every thread I read about hydro locking a motor with a cold air intake installed.
I went with the Comptech icebox myself and drive through puddles with confidence. Here's a picture of my Comptech icebox with a OEM Integra Type R air tube.
That valve cover is just a test fit for a future camshafts and cam gears install.
Also, here's a small article for you if you want to read up on intakes. Click here
