which springs?????
Old Oct 9, 2002 | 08:16 AM
tilt's Avatar
tilt
In my experience I had to consider ground clearance, tire clearance, ride quality/comfort, and handling/body roll.
For me a modest drop was a good idea considering the tegs are already pretty low stock as well as having small wheel well clearance. I didn't want to bottom out at every bump or rub my tires. Then there is ride quality and handling performance. These go pretty much hand in hand. If you want both, a combination of higher spring rates for front and lower for the rear is good since ride quality is affected more by the rear springs. You can also change ride quality and handling with adjustable shocks but they can only perform as well as the springs they are paired with. That being said, I went with the pro-kits because they are a modest drop, and probably one of the best compromises for ride comfort and handling.
this might help help you decide...
from team-integra.net
Spring Front Lower Rear Lower Front Spring Rate Rear Spring Rate
3rd generation 1994-2001 Springs
Stock --- --- 212 lb/in 117 lb/in
Stock Type R 0.51" 0.51" 246 lb/in 140 - 246 lb/in
H&R OE 0.75" 0.75" 276 lb/in 220 lb/in
Neuspeed SofSport 0.75" 0.75" 250 lb/in 185 lb/in
A'PEXi Sport 1.18" 1.18" 296 lb/in 145 lb/in
Comptech Sport 1.25" 1.25" 331 lb/in 126 - 194 lb/in
Eibach Pro-Kit 1.3" 1.3" 331 lb/in 126 - 194 lb/in
Spoon Sports 1.3" 1.3" 363 lb/in 307 lb/in
Sprint 1.5 1.5" 1.5"
Eibach Sportline 1.8" 1.8" 360 lb/in 174 - 257 lb/in
H&R Sport 1.75" 1.5" 276 lb/in 276 lb/in
Neuspeed Sport 1.75" 1.5" 250 lb/in 185 lb/in
Neuspeed Race 2.0" 1.75" 455 lb/in 360 lb/in
H&R Race 2.0" 1.75" 460 lb/in 350 lb/in
Sprint 2.5" 2.25"
Skunk2 sleeves 0 - 3" 0 - 3" 500 lb/in 400 lb/in
Old Oct 9, 2002 | 09:48 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I tend to like H&R's choice of spring rates more than anybody else's. They do a good job of not encouraging more understeer than necessary. If you don't want anything drastic the OE Sport are a great choice, they don't lower the car a lot which is the main stressor of the stock shocks aside from the stiffer spring rates themselves.
Old Oct 9, 2002 | 06:21 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
If the ride height is a huge concern, you could always go with coilovers if you got the money for the real ones. I got Ground Control because I can't afford true coilovers, and I love them. They are on stock shocks and struts. I am down about 2 inches and I still get great handling, ride, and looks. Just something to consider. Good Luck
angelgabe
9
Jul 12, 2006 06:42 PM
Dimi
92+ Civic/EL & Del Sol
37
Oct 23, 2003 07:12 PM
Creep
Sep 26, 2003 05:12 AM
lewylou78
Feb 16, 2003 12:56 PM
SpeedDriven
Aug 28, 2002 10:37 PM
