4-2-1 or 4-1 Header for a GSR
Old Mar 14, 2005 | 05:38 PM
davidn71's Avatar
davidn71
95 Civic w/ b16 swap
Originally Posted by DC2
4-1 is better suited, however you may run into ground clearance problems when you approach low objects on the road you normally run over. Be more careful.
True dat. I have a 4-1 on my b16a, and I literally lost about an inch of clearance...
Old Mar 14, 2005 | 06:01 PM
OilCanBoyd's Avatar
OilCanBoyd
is your car lowered?
Old Mar 14, 2005 | 07:22 PM
Illegal B16's Avatar
Illegal B16
New Zealand
Originally Posted by red94teg
How can you tell the difference between a JDM DC 4-1 Header and a regular DC 4-1? The reason I ask is because my header was already on the car when I bought it...
The difference is the collector mostly. A jdm 4-1 or a copy off it has a 2.5 inch collector, where a stock one has only a 2 inch. I just orderd a type-r copy in stainless steel which from dc sports is like $500 or something for only $200 shipped! (www.robearracing.com) Now the dc sport ones are carb legal, all except the type-r replica, and that goes for almost all headers i've looked at. A stock honda jdm 00 header goes for $450 and $70 for each heat shield. (there is 2) And that is the 2.5 inch collector everyone copies.
Now if you decide to go with this header you will still need to spend about $50 more, because it will not bolt up to your cat. You need a 2.5 inch flange and o-ring to make it fit on the cat which means welding is needed also. Not a stright bolt up item unless you already own a type-r.
Old Mar 15, 2005 | 07:02 AM
slvrteg's Avatar
slvrteg
big boys toys
If i was going to supercharge a gsr then 4-1 or 4-2-1 would be better? I'm thinking 4-1.
Old Mar 15, 2005 | 09:30 AM
Illegal B16
New Zealand
yes, still 4-1.
