upgrades
Old Mar 3, 2005 | 08:19 PM
tsizzle99's Avatar
tsizzle99
do you guys think if i were to go with some....Eibach Sportline Performance Springs, Camber Kits Skunk2 Front Upper Control Arms, and Skunk2 Racing Upper Front Strut Bars...would that be a nice setup?
Old Mar 3, 2005 | 08:27 PM
Snoopy's Avatar
Snoopy
been there done that
throw in some nice shocks and its a decent setup
Old Mar 3, 2005 | 08:29 PM
tsizzle99's Avatar
tsizzle99
http://www.modacar.com/products/Acura/Integra/MODASHS/
do those struts come with springs? so if they were to come with spring wuld i just use those? instead of the sportlines? if so i'd get those and and skunk 2 front upper control arm chamber kit?? wuld that be right?
Old Mar 3, 2005 | 08:33 PM
tsizzle99's Avatar
tsizzle99
or maybe the cheaper way....KYB AGX High Performance Shocks/ Strut / KYB AGX Struts (if they come with springs...not sure...) and Camber Kits Skunk2 Front Upper Control Arms...wuld that be good?
Old Mar 3, 2005 | 08:37 PM
Snoopy's Avatar
Snoopy
shocks and springs are two seperate things. they dont come together. unless you buy a full coilover shock/spring set. but those are $$$.
Old Mar 3, 2005 | 08:44 PM
tsizzle99's Avatar
tsizzle99
so fro like 600 bucks tell me wut u think i shuld get...
tsizzle99's Avatar
tsizzle99
well....around 600
Old Mar 3, 2005 | 09:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You also need a rear camber kit since the camber will most likely be more out of spec after lowering in the rear than in the front. I have KYB AGX shocks with Neuspeed race springs and ingalls camber kit in the rear and Skunk 2 in the front. I love the setup. It was cheap and it handles like a dream. For a less aggressive drop, I would recommend the Neuspeed sport springs. The stock GSR strut bar in the front is all you will need, then get a Comptech swaybar-tie bar combo and it will really handle nicely. The whole setup will run you over $500 but it is far better than any engine upgrade that you can buy for $500.
Old Mar 3, 2005 | 09:24 PM
tsizzle99's Avatar
tsizzle99
if i were to buy KYB AGX High Performance Shocks/ Strut / KYB AGX Struts and Lowering Springs Eibach Sportline Performance Springs...wuld that be a good setup? or do i need the chamber kits?
Old Mar 3, 2005 | 09:45 PM
Provocateur
On permanent hiatus
You will need camber kits. The drop is 1.7" and my philosophy is: 1"-1.5" drop will need camber kits if alignment shop says so and 1.5"+ will need camber kits regardless.
