Need some help
i just bought a 95 GSR and while i was driving my ABS light came on. The brakes feels good no problems at all the fluid level is normal what can this be?
but here is what i really need where can i find the OBD 1 connector so i can plug in my scanner? i couldnt find it today
Also i want to install some killing switches does any one know where i can hook them up and how?
Or does some one know how to get the code with using a paper clip?
http://www.c-speedracing.com/faq/06.php
and a list of the codes:
http://www.c-speedracing.com/faq/05.php
Looks like that c-speed link is for engine codes. ABS codes are different but you read them the same way.
Jumper the SCS connector with a paperclip or whatever... turn on the ignition. The check-engine light will either turn on solid (no engine codes) or it will blink it's OWN code.
ABS lamp will blink out ITS code is like this...
long flash - long pause (this isn't the code yet).
short flashes = first digit
short (1 second) pause
short flashes = second digit
long (5 second) pause
next error code, or repeat the same one...
Here's the codes...
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
(Beginning in '98 there's a whole different system with different code numbers...)
Here's the codes...
(94-97) ABS DTCs...
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
