Distributor Rotor
Old Jan 31, 2005 | 02:10 PM
BlaqueGhost's Avatar
BlaqueGhost
Default Distributor Rotor
i am having trouble starting my 90 RS, i checked for spark at the distributor and there was very little on 1 and none on 2 others... i searched the forum and a lot of results said change the cap and rotor i have the service manual but its very vague on how to change the rotor... any one have detailed instructions on how to change the rotor?
Old Jan 31, 2005 | 02:51 PM
badboy58's Avatar
badboy58
its one screw....when you take the cap off, there is a rotor that you just need to move in a circle till you see the screw, take the screw out, and its off. Not very hard at all
Old Jan 31, 2005 | 07:20 PM
BlaqueGhost
okay thanks, any way to turn the rotor? other than cranking the engine
Old Feb 1, 2005 | 04:00 AM
badboy58's Avatar
badboy58
no, unless you take the dist off
Old Feb 1, 2005 | 11:19 AM
BlaqueGhost
i see the screw but there is no way to get a screwdriver in there, anyone ever done this before?
90 RS
Old Feb 1, 2005 | 11:29 AM
badboy58's Avatar
badboy58
I have done this before, and there is room to get a screwdriver in there, I just did it. You can take off the dist with 4 bolts if that helps, but i was able to get to mine with a small screwdriver
Old Feb 1, 2005 | 11:54 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Yes, but it's too much work. You can jack up the front end, remove the driver's side front wheel, and manually turn the crankshaft, but it's easier to just turn the engine over.
But DON'T FORGET TO REMOVE ALL POWER WIRES GOING TO THE DISTRIBUTOR before doing this, or you can easily end up with a burnt coil like me h:
Old Feb 1, 2005 | 05:38 PM
BlaqueGhost
okay thanks for all you help
there was a little plastic cover i had to take off the bottom in order to clear a way to the screw
i got a strong spark on all 4 now but the car still isn't starting
any suggestions for the next step?
my best guess is spark plugs and fuel filter
Old Feb 1, 2005 | 05:40 PM
Tobra's Avatar
Tobra
If the car is in gear, you can spin the motor by rolling the car. Compression may be too high to do this without removing the plugs in a honda, but you can turn a VW bug over by hand
Old Feb 1, 2005 | 07:27 PM
StkyKiD84's Avatar
StkyKiD84
do you have spark on all 4 plugs now? or are you still missing spark in two cyl.?
