Rotor stud broken...
Old Jan 30, 2005 | 05:49 PM
94acu_integ's Avatar
94acu_integ
Default Rotor stud broken...
...well, two studs where i put my tires (rotor?) have broken and the other one came right out....how can i fix it or how much will it cost to repair the two studs....
Old Jan 30, 2005 | 05:53 PM
twin3037's Avatar
twin3037
50-60 dollars at a shop
Old Jan 30, 2005 | 06:04 PM
ohbiskits's Avatar
ohbiskits
the lug stud?...on my civ i had a period of time where they were spining left and right..every other time i took a tire off one stud would spin so id have to drill the lug nut out and put a new stud on...now on a 4th gen civ they are very easy to replce..they are less then a buck a peice and all u have to do it take the break caliper off and the stud is actually on the spindle or the "hub". if they have spun and lost the teeth they will push right out otherwise u may have to use a hammer...they will come out and then u just put the replacement stud in and hit it fromt he back a few times and oonce u get the teeth set..u can put a lug nut on and tighten it down and the stud will further set in place...on my civic i had to grind one part of the round backing on the stud flat to put it in but...now i havent looked at the breaks on my teg yet so im not positve this will be the same for u but if its the same as the civic...you can do it with about 15 min (for ur first time) and if u need three studs then about 4 bucks or less
Old Jan 30, 2005 | 06:29 PM
94acu_integ
well..how do i take off the break calibur...aint' it hard to take out...just wondering
Old Jan 30, 2005 | 06:31 PM
ohbiskits's Avatar
ohbiskits
no should just be 2 bolts
Old Jan 30, 2005 | 07:08 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You should get the loose one spot welded on the back of the hub to make sure it stays secure.
Old Jan 30, 2005 | 09:37 PM
LT's Avatar
LT
The deer had to die!
cost me $35 at honda to replace a broken rear wheel stud.
Old Jan 31, 2005 | 08:25 AM
94acu_integ
weld? what if it breaks again and then it'll be harder to replace.....anyways, what if i just buy some studs and hammer it into the hole...will the teeths hold good? if it does i'm going to just do that and save some money....??
Old Jan 31, 2005 | 05:11 PM
ohbiskits's Avatar
ohbiskits
mine have held up so far...i think it will be ok for you..when u remove your wheels do u use a impact wrench or just a tire iron?...the studs become loose and the teeth ware when u tighent tghe lug nuts too hard with a tire iron so just be careful...if the loosen too much and ware to big of a hole for the teeth to bite go ahead and tack weld like one or 2 welds on the back of the stud..a little grinding will qllow them to come off easy if they break again
Old Jan 31, 2005 | 06:19 PM
94acu_integ
thanks...
