rust?
Old Jan 27, 2005 | 05:39 PM
ohbiskits's Avatar
ohbiskits
Default rust?
what would you guys recomend for rust..my 90 ls 4 door has a little rust just along the bottom edge of the car...i guess my best bet would be to sand/grind it down and spray like sealer primer or somthing...u guys have any other suggestions?
Old Jan 27, 2005 | 05:58 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
need to replace the metal. Just sanding it down and covering it won't get rid of it. Chances are if it's there...then it's spread a little more. If you know what you're doing...you need to cut out the section that's rusted (and a little more) and replace it.
Old Jan 27, 2005 | 08:21 PM
Schwa's Avatar
Schwa
Schiggity
Same problem =(.
Old Jan 27, 2005 | 09:09 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What's rust? :chuckles:
Old Jan 28, 2005 | 06:59 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
Rust in unheard of on a Integra or hell any Honda! :shocked:
If you want to do it the right way cut out the metal and weld in new metal or you can sand it down use A LITTLE Bondo and paint it
Old Jan 28, 2005 | 06:51 PM
ohbiskits's Avatar
ohbiskits
thanks for your imput guys...ill update you with what i do
