S mode
Old Jan 20, 2005 | 08:50 PM
gascanb's Avatar
gascanb
Default S mode
Anyone used or use the S mode?
If so, in which circumstances?
Old Jan 20, 2005 | 09:43 PM
dustimus's Avatar
dustimus
Better golfer than you
WTF is s mode?
Old Jan 20, 2005 | 10:16 PM
gascanb's Avatar
gascanb
Its on the auto tegs
Old Jan 20, 2005 | 10:30 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It allegedly moves the shift point higher for more "aggressive" driving. I wouldn't use it unless you like wasting gas at a minimal advantage.
Old Jan 20, 2005 | 11:52 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
yeah it just shifts gears at a higher rpm shift point and holds low gears longer
you can do the same by stepping harder on the gas
Old Jan 21, 2005 | 12:09 AM
Kai's Avatar
Kai
Rotorphile.
It's a G2 auto thing.
If you mash the throttle in S3 or S4, the car will hold the gear to redline. Normal "D" mode will shift lower. Back when I had my G2, I always drove in "S" mode.
Old Jan 22, 2005 | 08:59 AM
Robstunner's Avatar
Robstunner
y0! Vito!
S mode does eat up gas faster though, obviously
Old Jan 22, 2005 | 09:05 AM
LT's Avatar
LT
The deer had to die!
i would use S-mode, especially if my G2 (if i had one) was auto.
Old Jan 22, 2005 | 09:55 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
SMode? :chuckles: I guess if you wanna burn gas you should use it, i don't think its gonna make your car any faster though
Old Jan 22, 2005 | 09:58 AM
LT's Avatar
LT
S-mode = Sport Mode
and it will make it slightly faster because the engine's power peaks around 6200 RPMs. normal auto's will shift before that peak.
