changin axle
Old Jan 15, 2005 | 01:36 PM
datkhmer's Avatar
datkhmer
Default changin axle
im tryin to replace the axle on my ls and i noticed two things. first, im missing two screws for the rotor, where can i get some, and second, the bolt wont come off for the axle. me and a friend think a portion of it is welded in cuz the impact gun and breaker bar isnt budgin it and it looks like nothing but metal there. also is it a bad sign when tryin to remove that bolt that a 180lb man and a 170lb can stand on it and it just holds us in the air?
Old Jan 15, 2005 | 02:09 PM
teg92's Avatar
teg92
WHAT OK YEAH!
i dont think they would weld that bolt on there. Its just probally seized did you try spraying some wd-40 or PB blaster?
Old Jan 15, 2005 | 05:15 PM
datkhmer's Avatar
datkhmer
we sprayed some lube on it whats a pb blaster?
teg92's Avatar
teg92
WHAT OK YEAH!
pb blaster is another kind of lube but alot stronger and better
Old Jan 15, 2005 | 05:26 PM
datkhmer's Avatar
datkhmer
i also wonder what is it meant by a warped rotor and seized caliper
Old Jan 15, 2005 | 05:33 PM
teg92's Avatar
teg92
WHAT OK YEAH!
Means your rotors need to be replaced, Dont think that has anything to do with the bolt not coming out
Old Jan 15, 2005 | 09:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They stake the axle nut from the factory. See if you can push the stake out with a chisel or something to make the nut round again. This helps to get it off. About the rotor screws, they are kind of pointless and when replacing the rotors, can be a total bitch, but you can pick up a few at the dealer for about $.80 a piece.
Old Jan 15, 2005 | 10:24 PM
dubcac's Avatar
dubcac
I
The rotor only uses 2 screws I believe anyways...you don't need 4.
As for getting the axle nut off, I used a 1/2" breaker bar...then slipped the hydraulic jack handle over the breaker bar...so it was about 4 feet long. That's enough torque to get it off.
Old Jan 15, 2005 | 10:29 PM
Provocateur
On permanent hiatus
It is only two screws. There are 4 holes in the rotor but only 2 in the hub.
Old Jan 16, 2005 | 04:24 PM
datkhmer's Avatar
datkhmer
i appreciate the responses...and an update on it we finished the driver side after 2-3hrs...after an 1hr 30 mins of chiseling and thinking :thinking: my next door neighbor (who just barely moved here from vietnam 3-4 months ago) came and help us after watching...he brought out one of those things that you drill in the wood to make a round hole (its like a chisel but in the middle it has a sharp point...i saw it at the store also and had a feeling i should of bought that instead of the chisels ) and in about a minute he shamed us and gets a good space and loosens the nut h:
tomorrow imma hit up the passenger side looks much easier then driver side
