progress camber kit
Old Jan 11, 2005 | 09:25 PM
datkhmer's Avatar
datkhmer
Default progress camber kit
would the progress camber kit be sufficient with a h&r sport spring drop (1.75) in the front? and whats the adjustability range of them, i heard it wasnt much probably less then 2
Old Jan 13, 2005 | 05:15 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I have the Progress Springs/Camber Kit to a 2 inch drop and rides great w/KYB 4-way adj. struts. The drop is decent, and you still have plenty of clearance.
Old Jan 13, 2005 | 08:20 AM
carta79's Avatar
carta79
Life after death
I'm pretty sure the max degree is 1.75', you should be fine with that setup.
Old Jan 13, 2005 | 09:02 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I installed a Progress camber kit on a teg and it had no adjustment whatsoever. They even capitalized on the 'washer trick' by including longer bolts and a bunch of washers as their 'rear camber kit'.
This was about 2 years ago so they might have changed it since then. Be warey of kits that are not adjustable.
Old Jan 13, 2005 | 10:08 AM
carta79's Avatar
carta79
Life after death
Here's some specs from coximports. Click here
This is what the progress front pivot mount should look like, I reckon.
Old Jan 13, 2005 | 10:14 AM
teg92's Avatar
teg92
WHAT OK YEAH!
I would go for a skunk 2 camber kit IMO
Old Jan 13, 2005 | 10:17 AM
HaRdCoRe TeXaS's Avatar
HaRdCoRe TeXaS
Acura = Hardcore
isnt skunk 2 usually more expensive?!?
Old Jan 13, 2005 | 11:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
ya but you get what you pay for
Old Jan 13, 2005 | 11:28 AM
westcoaststyle
Exactly... and they have replacement ball joints for the Skunk2 for only like $50. Thinking about getting those over the Ingalls I have now.. Ingalls design is kinda dumb and doesn't work all that well...
Old Jan 16, 2005 | 08:33 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Do you mean adjustment as in alignment? Cause I have not had any issues getting my car aligned. It's perfect. What year Integra did you install that on? I have it on my 99, is it possible the designe may have changed? If anything, I have more uerathane than washers.
