Help
Old Jan 11, 2005 | 08:27 PM
IKilledMYFamily's Avatar
IKilledMYFamily
Default Help
Okay, my teg was fine earlier, it is my daily driver, for work and what not. But, since i got home, i came in to my house and did my thing, went out to my car to take a cruise, and wham.. no power. I turn it, and everything comes on, beeping happens, BUT .. when I go to start it, it cuts down as if it has no battery power.. I need this fixed before tomorrow morning, any ideas ?
Old Jan 11, 2005 | 08:44 PM
IKilledMYFamily
Also when turning on, hear nothing but rapid clicking.. like.. the noise for the blinker just x100 speed
Old Jan 11, 2005 | 08:46 PM
sstearns2's Avatar
sstearns2
When was the last time you put a new battery in it? Sure sounds like the battery is on it's way out. The clicking is the starter relay opening and closing quickly. The battery is strong enough to close the relay, but then the starter pulls the battery down very quickly to the point that it can't hold the relay closed and the relay opens back up. Then with the starter off line the battery once again has the power to close the relay and the cycle starts over.
Scott
Old Jan 11, 2005 | 09:44 PM
IKilledMYFamily
I tried to jump my battery, And it did the same thing, lights and beeping came on, but when i turn it, clicking.. like tktktktktkttktktktktktktktktk.. everytime.. if indeed it is the battery, i guess it was too dead to be jumped ?.. the past 2 - 3 days it has been starting a little slower than usual, instead of the tk tk START, it was more of a tk tk tk tk tk START..
Old Jan 12, 2005 | 07:54 AM
JimBlake's Avatar
JimBlake
If it was the battery, then jumping it would have worked. Look for dirty/loose/corroded battery cables. Especially the other ends, including the big fat ground cables.
Old Jan 12, 2005 | 08:48 AM
jame5x's Avatar
jame5x
Maybe the wire to the starter is loose. Thats what happened to mine
Old Jan 12, 2005 | 09:12 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
check if you're getting spark
Old Jan 12, 2005 | 11:50 AM
brothalynchhung's Avatar
brothalynchhung
hehe id say is battery issue,
Old Jan 12, 2005 | 11:52 AM
escrayzee's Avatar
escrayzee
like they said.....could be your battery or your alternator......it happend when my girlfriend had a dumb Hyundai Accent. same description as you. took it in for diagnostic and the alternator was on its way out........swapped the alternator myself then some foreign old geizer tboned her a few weeks later and the car was a write-off......good........now she's got an integ
Old Jan 12, 2005 | 02:16 PM
dustimus's Avatar
dustimus
Better golfer than you
Check the line to your starter. Same thing happend to me, theres a little boot covered wire going into the top of the starter. Make sure its making good contact.
