speedometer wobbles at high speed
Old Jan 10, 2005 | 01:37 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Default speedometer wobbles at high speed
speedometer wobbles at high speed, like above 60ish.
whats wrong with it? how do I fix it?
"no officer, really I don't know how fast I was going. I could have been anywhere between 65 and 75." h:
Old Jan 10, 2005 | 01:39 PM
VPUPPY's Avatar
VPUPPY
what year is your car?
Old Jan 10, 2005 | 01:45 PM
clickwir's Avatar
clickwir
oh sorry. 93 integra LS.
Old Jan 10, 2005 | 01:48 PM
VPUPPY's Avatar
VPUPPY
on some older honda/acuras, they actually used a speedo cable, not a wire driven speedo. i think your car may have the same, somebody correct me if i am wrong. i know those used to cause wobbling speedos cuz it gets worn out. just a thought.
Old Jan 10, 2005 | 02:19 PM
clickwir's Avatar
clickwir
I don't know for sure, but I'd have to agree. When it's cold, I can hear what sounds like a spinning cable behind the instrument cluster. But that's usually associated with the tach, not the speedo.
It is on the older side so it very well could be time for replacement.
I take it, it's not easy getting back there eh?
Old Jan 10, 2005 | 03:04 PM
VPUPPY's Avatar
VPUPPY
hey, d/l your service manual @ http://www.hondahookup.com/manuals/. i looked through it and it seems i was incorrect about the cable. it seems that the vehicle speed sensor is not hooked up to a cable, it is hooked up by a wire. i suggest you d/l it and follow the trouble shooting precedures in chapter 11. you will need a digital multimeter.
btw, i suspect a bad vehicle speed sensor or loose connection.
Old Jan 10, 2005 | 03:09 PM
clickwir's Avatar
clickwir
sweet. thanks.
multimeter is not a problem... Fluke is a good friend
Old Jan 10, 2005 | 03:15 PM
dubcac's Avatar
dubcac
I
It's probably your VSS.
Old Jan 10, 2005 | 03:18 PM
clickwir's Avatar
clickwir
Is this something I can get to and look at to see if it's bad or worn or dirty?
Old Jan 10, 2005 | 03:36 PM
dubcac's Avatar
dubcac
I
The VSS bolts into the top of the transmission. Download your manual from the link above, it'll show you exactly where it is. I don't know what you can do besides swap in a known good one and see if the wobbling stops.
