Irratic Idle And Code 21
Old Jan 9, 2005 | 05:37 PM
mtacura's Avatar
mtacura
MTACURA
Default Irratic Idle And Code 21
Whats Up, I Just Swapped A 98 Gsr Into My 2001 Ls. Everything Is All Gravy Except For A Damn Code 21, And An Irratic Idle. It Hops From 1000 Rpms Up To About 1500 R's. I Am Running An Obd 1 P72 Chipped Ecu, With An Obd2b To Obd 1 Conversion Harness. Right Now Everything Is Still Pretty Much Stock. I Want To Get It Running Awesome Before I Make It Go Faster. Any Help Would Be Greatly Appriciated.
Old Jan 9, 2005 | 05:40 PM
LT's Avatar
LT
The deer had to die!
code 21 is the VTEC solenoid valve
irratc idle could be IACV or fast idle thermo valve
Old Jan 9, 2005 | 05:44 PM
mtacura's Avatar
mtacura
MTACURA
Default code21
i checked all the wiring on my vtec, its all good, the solenoid click like its suppossed to. how do i check the fast idle valve?
Old Jan 9, 2005 | 06:26 PM
LT's Avatar
LT
all you can do is replace it. there is really no way of checking it.
Old Jan 9, 2005 | 07:02 PM
mtacura's Avatar
mtacura
MTACURA
what about the code 21?
Old Jan 9, 2005 | 08:08 PM
dubcac's Avatar
dubcac
I
Check all your vacuum hoses and connections for leaks...vacuum leaks can cause an erratic idle. Does it still happen while the car is warm? The fast idle thermo valve only controls idle while the engine is cold. Also could be a faulty/stuck IAC valve.
