OEM Fog lamps
Old Jan 3, 2005 | 08:51 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default OEM Fog lamps
I currently have a set of OEM fog lamps on my Integra, but I want to wire them up to my parking lights instead of my headlights. Any help would great. Thanks
Old Jan 3, 2005 | 10:02 AM
BONE's Avatar
BONE
I wanted to do the same to mine but thought it would be too much of a hassle.
Old Jan 3, 2005 | 01:01 PM
LT's Avatar
LT
The deer had to die!
why the parking lights? don't they operate the same?
my JDM foglights are wired to receive signal from the dashlamps and USDM fog switch on my center console
Old Jan 3, 2005 | 01:03 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Mine only come on with the low beam headlamps.....
Old Jan 3, 2005 | 01:08 PM
LT's Avatar
LT
did they come with the integra from the factory? do you know if they were dealer installed? if you did it yourself...why not just rewire it yourself?
if team-integra was working properly i would give you a link to the article that helped me wire up my fogs.
Old Jan 3, 2005 | 01:16 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
They appear to be factory or a factory accessory. The switch is in the center console......
Old Jan 3, 2005 | 01:34 PM
LT's Avatar
LT
dealer installed. if you follow the switch harness into the steering column, you can pull the connector between the headlight harness and the combination switch. then you can wire into the in-dash fusebox and wire into a signal lead.
Old Jan 3, 2005 | 03:17 PM
LatinDC2's Avatar
LatinDC2
My bro recentyl installed his..and followed this...Im not sure if it will work with the Acura fogs?
Click me
Old Jan 3, 2005 | 06:12 PM
AcuraGyrl's Avatar
AcuraGyrl
I want some for my car but I am not sure where to get them from.....any ideas?
Old Jan 3, 2005 | 06:28 PM
LatinDC2's Avatar
LatinDC2
Well chica there wasnt any OEM fog lig for 94-97 tegs... but u can the JDM one...
