Crank Pulley Bolt
Old Oct 6, 2002 | 12:29 PM
g2tegls's Avatar
g2tegls
MR, ftw
I must be a tard cause I didn't see a plate.
Old Oct 6, 2002 | 12:31 PM
lttletimmy's Avatar
lttletimmy
under the car, take off the big black brace. Then right next to the passenger side of the oil pan there is a black, thin plate covering the flywheel attatched to the tranny. I think it's held on by about 6 small bolts. That's the covering for the flywheel. Good luck
Old Oct 9, 2002 | 02:46 PM
g2tegls's Avatar
g2tegls
MR, ftw
Thanks Littletimmy, I finally got it. I found the plate, took all the crap off around it, took it off and inserted an alan wrench between the teeth of the flywheel. Sure beats paying $60 for a special tool.
I tried using an air powered impact wrench but that didn't budge it. Finally, I used an 18" breaker bar with a 1/2" drive, with an adapter to fit my 3/8" drive 19 mm socket. Well, I broke two of those adapters so then I just bought a 1/2" drive 19 mm socket. I leg pressed the fvck out of it and the damn bolt finally gave up and broke loose. I was about to give up and put all the sh1t back together and bring it to a shop. That woulda been teh :ghey:.
:yay:
Old Oct 9, 2002 | 04:14 PM
Tony96EX's Avatar
Tony96EX
Originally posted by lttletimmy
I've done this quite a few times, i find the easiest way is to jack the car up, take off the plates covering the flywheen on the tranny, then take a big screwdriver and stick it in the teeth on the flywheel and brace it. makes it pretty easy and i've never broken a tooth or anything
I've tried that before and it didnt work for me. We had to get the moroso crank tool $70. BTW this tool fits all B series motors.
Old Oct 9, 2002 | 05:43 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
why don't you guys just go out and buy the moroso tool for removing the crank bolt.
Project EVA - The Track Package
Project EVA
Old Oct 9, 2002 | 10:53 PM
lttletimmy's Avatar
lttletimmy
:yay:
:thumbup: Congrats, glad i could help
Old Oct 10, 2002 | 06:00 AM
qtiger's Avatar
qtiger
Where would one find the Moroso tool?
Old Oct 10, 2002 | 09:33 AM
g2tegls's Avatar
g2tegls
MR, ftw
www.summitracing.com i think has them. No store I went to has them.
I didn't buy one cause I don't wanna pay $70 for a tool I'm gonna use once and I don't really wanna wait days or weeks for it to come since I already have everything apart.
Old Oct 10, 2002 | 10:37 AM
tilt's Avatar
tilt
Just wondering, would this work if all the belts are off?
Old Oct 10, 2002 | 11:17 AM
g2tegls's Avatar
g2tegls
MR, ftw
yes, it makes no difference if the belts are on or off but you have to take them off to get the other things off anyway.
