Vtec Problems
Old Jan 5, 2005 | 08:06 PM
integravtec96's Avatar
integravtec96
Default Vtec Problems
I recently started hearing a weird noise when my Vtec is "suppose" to engage. I disconnected my Vtec harness that connects to the solenoid and the harness to the pressure switch and the noise stopped. I got a new pressure switch and reconnected the harnesses but the noise is still there. It sounds like a rattling noise from the engine and you can hear the exhaust popping like when your plugs are going bad. A GSR without Vtec isn't much fun. Need help!
Old Jan 6, 2005 | 01:09 AM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
Does the vtec pulsate(engage and disengage) after the engagment point? Or basically a lack of power? Did you replace just the pressure switch or the whole solenoid. The whole solenoid has 3 bolt that hold it to the block and has a screen to trap debree. I had problems with mine and the vtec would not engage at all so i replaced the whole solenoid(which is fairly easy so don't go to the dealer) and everything works fine now.
Old Jan 6, 2005 | 07:41 AM
integravtec96
It feels like it pulsates. I replaced just the pressure switch and i also went a ahead and replaced the Vtec gasket with the screen. One thing i forgot to mention was that the problems started right after I installed the cam seal on the Vtec side. The one that is known for leaking. I replaced it with an AZ cam seal. I don't know if that cam seal would have anything to do with it.
Old Jan 6, 2005 | 05:47 PM
integravtec96
should i adjust the valves?
Old Jan 6, 2005 | 06:59 PM
dubcac's Avatar
dubcac
I
Try adjusting your valves and see if that helps. It could be your lost motion assemblies going bad though.
Old Jan 7, 2005 | 12:00 PM
integravtec96
did a valve adjustment today but probelm is still there..the noise sounds like its coming from the bottom of the engine..could it be a clogged cat?..because after the car heats up for awhile, it doesn't make the noise...hmmm
Old Jan 7, 2005 | 03:38 PM
dubcac's Avatar
dubcac
I
If it only happens while cold, dont worry about it. Make sure you have enough oil, and it's clean.
