cam help
Old Jan 5, 2005 | 07:07 AM
nasty-gsr's Avatar
nasty-gsr
Default cam help
i have bought a v-afc, type r pistons, full exhaust, intake, and i have a upgraded fuel pump ready to put on when i put the pistons in. i need help picking out a cam, i want it to run strong but i wasnt it to ideal well at the same time. any advice well be appreciated thanks
Old Jan 5, 2005 | 07:15 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Do you plan on staying NA or turbocharging??
Old Jan 5, 2005 | 07:37 AM
badboy58's Avatar
badboy58
well i take it you are gonna stay NA with Type R Pistons, if you want to do the Valvetrain upgrade then go with Skunk2 or Crower Stage 2 - 3, if no valvetrain, then skunk2 stage 1. I just did the same setup in my gsr....put type r pistons and rods with skunk2 stage 1 cams and intake manifold. Sounds nice.
Old Jan 5, 2005 | 09:42 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
CTR cams aren't bad if you want the best drivability.
If you want something more aggressive, something like Skunk 2 or crower like mentioned before are best. If you have to deal with smog, you are limited to stage 1. Stage 2 would work if you upgrade the valvetrain and don't mind a lopey idle.
Old Jan 5, 2005 | 09:48 AM
LT's Avatar
LT
The deer had to die!
yea, if you're just looking for a mild setup with no lopey idles and great driveability, the CTR & ITR cams are good along with Skunk2 stage 1's which are just every so slightly more aggressive than CTR & ITR cams.
Old Jan 5, 2005 | 10:15 AM
BONE's Avatar
BONE
What kind of car is it a LS or GS-R if you are looking for streetabilty stick with ITR's or if you want something a little more radical get the CTR's. You cant go wrong with either one and besides its a factory part so you know your getting the best possible cam as far as reliability is concerned.
Old Jan 5, 2005 | 11:14 AM
Snoopy's Avatar
Snoopy
been there done that
buddy club III's. they'll make more power than itr or ctr and you can use the stock valvetrain up to the stock redline. but upgrading to stiffer springs and retainers is always a good idea.
Old Jan 5, 2005 | 12:05 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
CTR Intake cam is a good deal w/best driveability.
Old Jan 5, 2005 | 06:28 PM
nasty-gsr's Avatar
nasty-gsr
thinks for the replies helped a lot still not sure if im just putting a cam in or the hole 9 yards
Old Jan 6, 2005 | 01:34 PM
AP2's Avatar
AP2
Moderator Alumni
You can't go wrong with CTR cams, it'll compliment the extra rpms you can run since you're enhancing your valvetrain.
