Can a p8r head be put on an b18b?
Old Feb 26, 2009 | 07:54 AM
IanB's Avatar
IanB
MB4
Originally Posted by JdmStoff
So far i can say i havn't lost power, bt i can't be certain until i get it mapped properly... y wud you loose power from bigger valves? the cams are from a 2litre so they peak lower than p75 from wot i have seen... my motor feels good bt we shall see if it lasts the dyno tuning
I didn't say you would lose power from the bigger valves, I suggested you could lose power from the head's combustion chamber being bigger than the cylinder bore, causing some funny airflow in the combustion chamber, possibly affecting flame front, and possibly causing hot-spots in the combustion chamber that could cause detonation.
B20z cams are the same as B18b, B20b intake cam is smaller but the exhaust is the same.
