jacksonracing gsr
Old Dec 29, 2004 | 11:19 PM
Jed parel's Avatar
Jed parel
Default jacksonracing gsr
does any one know if i should do any thing to the internals on my gsr supercharged
Old Dec 30, 2004 | 06:57 AM
ISP James's Avatar
ISP James
DAMIMRED
you dont have to do anything but a lower c/r and you can crank in more boost...
Old Dec 30, 2004 | 09:03 AM
Jed parel's Avatar
Jed parel
im not sure what c/r is
Old Dec 30, 2004 | 09:38 AM
ISP James's Avatar
ISP James
DAMIMRED
compression ratio
Old Dec 30, 2004 | 09:47 AM
Mackenzie C's Avatar
Mackenzie C
you could do this by getting a thicker head gasket.
Old Dec 30, 2004 | 09:49 AM
ISP James's Avatar
ISP James
DAMIMRED
yeah that would be far easier than replacing the pistons :goodjob:
Old Dec 30, 2004 | 09:51 AM
Mackenzie C
oh fo sho
Old Dec 30, 2004 | 11:06 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I really wouldn't worry about lowering the compression with a JRSC. The most you could do with a supercharger is about 10-11 psi, then you start running into all sorts of heat effeciency issues with those things, and possibly some nasty detonation. If you engine is solid, passes leak down and compression tests, 10psi with lots of tuning would be your best bet with that blower.
Old Dec 30, 2004 | 01:15 PM
Jed parel's Avatar
Jed parel
where can i get the gasket from or can i use a block guard
Jed parel's Avatar
Jed parel
so my setup is just fine the way it is
