How does the shift boot come off
Old Dec 27, 2004 | 09:07 PM
brothalynchhung's Avatar
brothalynchhung
Default How does the shift boot come off
I know it probably just pulls off like every other panel but on my integra it seems to be harder then it should be... is there a trick to it.. id rather not break pins.... Anyone ?
=) thanks
Old Dec 27, 2004 | 09:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to remove the center console by unscrewing a bolt beside each seat, two up front and two in the holder under the e-brake. Then it should come off in two pieces. The shift boot unscrews from underneath the piece that is closest to the radio. Hope that helps. Just make sure that you unscrew everything and pull gently as to not break anything.
Old Dec 27, 2004 | 09:25 PM
brothalynchhung
u sure it seems theres a little plastic panel that the shift boot is connected to that seems to move a bit.. it looks like u can pop it off....
Old Jan 2, 2005 | 09:43 PM
neeman77's Avatar
neeman77
u cant. u gotta take the center console out
Old Jan 3, 2005 | 04:55 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I second this, the center console does need to come out. There is a bracket that the shift boot stretches over and then on each corner there is screws securing the boot to the bottom of the console. If you yank it out and get it out it is because you broke it, then your new bag will be worthless, you'll need a new bracket and in the meantime your bag will sag down and you'll be able to see around it.
Old Jan 3, 2005 | 05:20 PM
brothalynchhung
its ok i like saggy bags
Old Jan 3, 2005 | 05:23 PM
LatinDC2's Avatar
LatinDC2
Do what he said...or you'll break the clips.
Old Jan 3, 2005 | 07:44 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Ok man, to each is own, different strokes for different folks. I like my fun bags perky though...
Old Jan 6, 2005 | 12:15 PM
neeman77's Avatar
neeman77
yeah i bought a new shift knob and the boot was sagging down so i took out the center console to get underneath it. Its pretty striaght forward once u start tackling it. screws are in weird places like behind the cigarette tray :s
Old Jan 6, 2005 | 01:17 PM
AP2's Avatar
AP2
Moderator Alumni
You'll have to take the center console out.
