Gauge cluster+Clock not working?
Old Dec 18, 2004 | 10:27 AM
HPIracing's Avatar
HPIracing
Default Gauge cluster+Clock not working?
I have a 95 gsr and all of the sudden my gauge cluster and clock do not function, they are both stock. I checked all fuses, the cluster illuminates but nedles and gauges do not function and the clock went out at the same time. Has anybody had this happen to them before? if so what fixed it??
Old Dec 18, 2004 | 11:01 AM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
There is a fuse panel under the hood as well. Check those. There is a diagram in the book if it is not on the cover. If not the problem, then most likely a short of some kind.
Old Dec 18, 2004 | 11:08 AM
HPIracing's Avatar
HPIracing
ive checked every single fuse under the hood and under the dash all is OK. I pulled the cluster out to see if there was a fuse there but no. what else?
Old Dec 18, 2004 | 12:41 PM
meangreen96
My guess is that it is a grounding issue. I had my guage lights go out in my teg and it ended up being the ground wire between the fader dial and the cigarette lighter. So i had to rerun the wire. I will check my book to see if there are some obvious grounding points. And if the clock is connected to the cluster via ground. Will post a bit later.
Old Dec 18, 2004 | 01:10 PM
teg92's Avatar
teg92
WHAT OK YEAH!
you could have a short somewhere like Meangreen96 said check for ground
