2500 RPM Noise
Old Nov 17, 2004 | 05:06 PM
dubcac's Avatar
dubcac
I
Originally Posted by OilCanBoyd
How much for an exhaust manifold?
You can check yours for cracks/leaks by looking at it from underneath. Aftermarket headers are usually $300 or so and up. I would try taking the cat heat shields off first.
Old Nov 17, 2004 | 08:44 PM
rslsgsr's Avatar
rslsgsr
poor hungry dirt kid
yeah, i get a metal humming noise at about 2700...
everytime i hit 2700 rpm i could hear it and when i go past 2800 rpm it stops...
if i keep my needle at 2700-2800, it is a constand humming noise....
but then again, my car makes so much noise... i learn to accept it...
Old Nov 17, 2004 | 10:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The A pipe is usually the one that poops out. An OEM replacement will run you $600 whereas you could replace the whole manifold with an aftermarket for less than $300 and get some HP gains from it.
Old Nov 21, 2004 | 02:17 PM
OilCanBoyd's Avatar
OilCanBoyd
My shop helped me determine that it is the A pipe. What is a good header for this car. If it helps performance that would be great. I'd like to keep the pice down. The car is stock. Thanks
Old Nov 21, 2004 | 03:50 PM
LT's Avatar
LT
The deer had to die!
the header bracket (bolts to collector and engine block) can break in half, resulting in the 2 pieces vibrating against each other. this happened to me, and i just removed it - problem solved.
Old Nov 21, 2004 | 06:04 PM
Provocateur
On permanent hiatus
DC Sports. Either ceramic or ss. Stainless Steel looks better and lasts longer but is a bit more expensive. It will probably run you about $300-350 for a new one.
Old Nov 22, 2004 | 06:13 AM
carta79's Avatar
carta79
Life after death
Originally Posted by silvagsr
If its an aftermarket exhaust, it may be your b-pipe. I had to replace my b-pipe on my comptech cat-back, and noise stopped.
Do you still have the Comptech B-pipe, or was it sold?
