Steering pulls left from a stop?
Old Nov 14, 2004 | 06:14 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
my 2000 LS doesn't do that..hmmm?
Old Nov 15, 2004 | 05:30 PM
Tobra's Avatar
Tobra
My GSR does the same thing, never have been able to diagnose the cause. Mine does it worst on Watt ave, which is a nightmare of rutted assfault(Ha) I guessed that mine was just the car following the grooves and ruts in the road.
Old Nov 15, 2004 | 11:11 PM
NewbieTEG's Avatar
NewbieTEG
I had the same problem with my 95 se, chalk one up for low end torque!
Old Nov 16, 2004 | 05:03 AM
VPUPPY's Avatar
VPUPPY
my 98 ls does the same thing only with no hands on the wheel(i don't do this often, just check the alignment from time to time) under medium acceleration. just pulls to the left. If i hold the wheel though, it does not do it and i find that i don't have to use much force to keep it straight.
Old Nov 16, 2004 | 12:23 PM
dubcac's Avatar
dubcac
I
Same here...that's torque steer.
Old Nov 18, 2004 | 02:35 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
what about when you shift quickly at high rpm in low gear and it turn to the left...is this torque steer also?
Old Nov 19, 2004 | 12:35 PM
b18teg's Avatar
b18teg
might be the balance its a tade off.. see if the lead weights they put on the rims are still on... its rare but they do come off...
Old Nov 19, 2004 | 03:09 PM
dubcac's Avatar
dubcac
I
Yes.
Old Nov 20, 2004 | 01:18 PM
superteg99's Avatar
superteg99
Yeh i would get it aligned and or check the tire pressure.
Old Nov 22, 2004 | 11:11 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Alignment and tire pressure should be checked to ensure the car is operating properly. If you still pull to the left that is most likely torque steer, although my Integra always has a slight pull to left.
