GSR-Top Speed
Originally posted by More&Faster
btw i think my speedometer is dead on accurate as well. that is assuming that my tach is accurate as well, but assuming that....you can just calculate your speed. dont even look at the speedo, just find out what your final drive ratio is and multiply it by the rpm shown on the tach.
Mike, why would the RPM guague be off by so much. I would think the speedo has higher room for error. The RPM guague is always dealing with a known set of numbers, no one is going to swap out different engine components enough that that guage should be inaccurate. Whats causes it to be off by as much as 500?
rpm tachs are usually off by about 500 rpms cause it runs off a wire by the ecu. it's not wired right to the distributor. that's why after market tachs are more accurate.
damn now I feel left out...the most I've ever taken my LS to was 105.........and in all honesty, I'm too scared to go any higher than that.......At those speeds, all I see are images in my head of a tire popping or brakes failing.............
It's happened to my dad before, so I guess I've sort of been traumatized by that
Originally posted by Novtec1
fastest to date was 146 in a 91 ls on autobaun 7...you gotta love Germany....and i still had about a grand left on the tach.
