LSD install
Old Aug 16, 2002 | 10:12 PM
99bajakid's Avatar
99bajakid
Default LSD install
How hard is it to install a LSD? Would it be impossible for me to do, should i have a shop do it?
Thanks
Nick
Old Aug 17, 2002 | 01:12 PM
Osman's Avatar
Osman
i heard that your supposed to only let honda transmission specialists do it...but i could be wrong.
Old Aug 17, 2002 | 01:23 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Its a lot more complicated than a clutch install. If you have to ask i'd say dont do it.
Old Aug 17, 2002 | 02:23 PM
Turbo Teggin's Avatar
Turbo Teggin
my friend is a mechanic and put my quaife in, but he ran into a problem, he had never worked on a honda b4 and there was something that he did when he put the tranny back together he didnt align something right, and when i tried to shift into second it would grind and not go in, so he took it back apart and he ended up not aligning something right, he said it was so stupid, if you really wanna do it take your time and only do it if youve know how to get it back together
Old Aug 17, 2002 | 05:10 PM
99bajakid's Avatar
99bajakid
Hmmm how much does a decent shop charge to do a lsd install?
Old Aug 17, 2002 | 06:02 PM
TheRooster's Avatar
TheRooster
Former Senior Member
I'm changing out the differential in my GS-R and it is entirely too easy. You've got to pull the axles, and drop the transmission. Then its a bunch of bolts, a snap ring, and a couple of shafts on the shifter assembly. After thats done, you take the gears out (they lift right out) and lift the differential out. You then transfer over the ring gear. Put the new one in, and here's where it gets tricky. You have to use a special tool to check the tension on your lsd. If its not within a certain limit, you have to get a new 79.5mm from honda, that will bring that torque into spec. You definitely need a helms manual. Then its just a matter of sliding everything back together. Be prepared to change your axle seals out though. Mine had some seepage and had to be special ordered through the dealer. Its only 20 bucks, so you might as well do it while its handy. Its better than ripping everything apart and waiting two weeks. You'll also want to replace a couple of crush washers in there.
Oh yeah... here's some pictures: LSD pics
Old Aug 19, 2002 | 02:16 AM
MY B18c's Avatar
MY B18c
you half to take it to a trans shop because it needs to be machined to much trouble if you have a gsr you really dont need a lsd it would be nice though
Old Aug 19, 2002 | 06:22 AM
BonzoAPD's Avatar
BonzoAPD
go to a shop and get it done unless you really know what your doing.
Old Aug 19, 2002 | 12:27 PM
TheRooster's Avatar
TheRooster
You're absolutely wrong. The only "special" adjustment to the whole process is ordering the right 79.5mm shim. The factory service manual comes with a table that tells you which shim you need to order to get the torque to come in. If anyone wants I could even scan the page and email it to anyone interested. Its a breeze.
eclipse spanker
12
Nov 20, 2010 09:46 AM
93ACCLUDE
Prelude
6
Jan 16, 2005 07:26 AM
pureGSR
CRX & Pre 92 Civic
6
Dec 22, 2004 07:47 AM
97sup-gsr
4
Oct 21, 2003 10:44 AM
dwnthehatch
92+ Civic/EL & Del Sol
5
Apr 14, 2003 06:10 PM
