Spring install PROBLEM
Old Aug 16, 2002 | 06:19 AM
DeadLock23's Avatar
DeadLock23
Default Spring install PROBLEM
I installed my H&R springs and kyb adjustable shock today.
The most upper part of the shock where the cap goes over the spring and it held by one screw was on pretty tight, I left about the same amount at the stock setup had when tightening it. But when the springs went on the car, and we lowered the car that screw got loose.
Now the washer under it is lose, is that how it's supposed to be, someone told me not to make it tighter because it might blow the shock?
oh and now my itr strut bar in the front doesnt seem to fit. what am I doing wrong?
I also hear weir noises when hit certain bumps. like minor rattling.
any advice help? I think I did eveyrthing as I should have.
Old Aug 16, 2002 | 06:29 AM
DeadLock23's Avatar
DeadLock23
anyone have a clue?
Old Aug 16, 2002 | 06:38 AM
reno96teg's Avatar
you should tighten it to spec. do you have a torque wrench?
Old Aug 16, 2002 | 06:42 AM
DeadLock23's Avatar
DeadLock23
does anyone know what the torque should be on the front and rear shock assembly holding the spring in place over the shock?
or anyone have a repair manual they can refere to?
thanks
Old Aug 16, 2002 | 09:14 AM
DeadLock23's Avatar
DeadLock23
i found out its supposed to be 22 according to my friend
Old Aug 16, 2002 | 06:12 PM
teggie tinker's Avatar
teggie tinker
i had the same thing happen to me its 22!!
good luck
Old Aug 16, 2002 | 09:37 PM
DeadLock23's Avatar
DeadLock23
if there is a lil liquid comin from the top, it comes up and seeps back in as I push down on that side of the car to see is the shock it working correctly, does that indicate a blown shock? or maybe soon to be blown
they are new, KYB AGX, I hope the warranty covers that.
Old Aug 17, 2002 | 09:30 AM
ur31337's Avatar
ur31337
Colby
It sounds like it's blown. Not so good.
How much of a drop are you running? KYB won't warranty over 1.5
Old Aug 17, 2002 | 06:38 PM
DeadLock23's Avatar
DeadLock23
1.7 in the front and 1.5 in the back
they are H&R springs Stage 2 sport springs.
weird, aftermarket shocks should be able to take this drop, I probably would have had better luck with stock ones.
anyways I dont think it's blown, cause the ride is fine, stiffer all around but doesnt seem like one side is worse in any way then the other.
Old Aug 17, 2002 | 06:40 PM
DeadLock23's Avatar
DeadLock23
and how will they know what springs I'm runnin on, I can tell em I have the prokit, 1.3 all around.
NOPD
Oct 5, 2004 12:01 PM
Jason852001
Do It Yourself
13
Jul 15, 2004 10:31 AM
GSR_PSI
2
Aug 9, 2002 07:06 PM
ChillOutWayne
Engine Swaps, Tech & Tuning
3
Jul 8, 2002 04:50 AM
