engine swap?
Old Oct 9, 2004 | 12:07 PM
bmr4193's Avatar
bmr4193
Default engine swap?
what sort of engine swap would be most logical and least expensive for a '96 LS integra? i want to be able to keep the a/c and things such as that.
Old Oct 9, 2004 | 12:42 PM
antarius's Avatar
antarius
Large Member
You could always just do a typical GS-R swap, or you could go ITR. It's going to be a lot cheaper and more performance oriented than putting another LS motor in there, and certainly a lot more reliable and cheaper than going with an LS-VTEC setup.
I'd go with a GSR swap just because it's cheap, reliable, easy, there's tons of them floating around and you can keep all the stuff you stated above you wanted.
Old Oct 9, 2004 | 02:16 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
Yeah, B18C all the way. My friend put one in his Civic. He got the Engine, harness, ECU, front axles and a few other things for about $3000. Type R motors usually run about $5000 with everything I just mentioned, and if I'm not mistaken, the come with a 6spd Tranny too. But B18C is probably your best bet.
Old Oct 9, 2004 | 04:19 PM
teg92's Avatar
teg92
WHAT OK YEAH!
whats wroung with the LS? I say just slap a turbo on there
Old Oct 9, 2004 | 05:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, only a 5 speed.
Yeah, go GSR. They have lots of potential and are relatively cheap.
