Clutch Problems 94 GSR
Old Sep 17, 2004 | 05:19 AM
intjinfj's Avatar
intjinfj
Default Clutch Problems 94 GSR
Yesterday I got into my car and the clutch was alot easier to push then it had been before. I also have to push the clutch in all the way and it is getting harder to shift. Any ideas? Do I have a Hydrodralic clutch and I just need to add fluid, any help would be great. I do not have any slipping in the clutch by the way.
Old Sep 17, 2004 | 06:14 AM
JimBlake's Avatar
JimBlake
You have a hydraulic clutch, and it sounds like you may have air in the lines. Adding brake fluid to the clutch reservoir is only the start. You have to bleed the clutch to remove the air.
Is there any evidence of leaking anywhere? If so that's a little more serious. Look under the carpeting by the clutch pedal, sometimes it leaks where the shaft comes thru the firewall.
Old Sep 17, 2004 | 06:34 AM
ISP James's Avatar
ISP James
DAMIMRED
like mine, just one of the many many many winter projects i have ahead of me.... :happysad:
does your clutch slip at high rpms at all?
Old Sep 17, 2004 | 07:20 AM
intjinfj's Avatar
intjinfj
I have no leaking fluids and the clutch does not slip what so ever.
Old Sep 17, 2004 | 11:47 AM
intjinfj's Avatar
intjinfj
BUmp Mechanic looked at it and filled cluth fliud because it was empty, and the clutch works great. Still have to make sure that there is not any fluid just leaking but drove it around and had no problems. BUMP!!!
intjinfj's Avatar
intjinfj
BTW my spelling sucks, I know I just type to fast and don't proof read
