car wont start please help
Old Sep 10, 2004 | 08:51 PM
spooncivicb16b's Avatar
spooncivicb16b
Default car wont start please help
gas is flowing checked that got new spark plugs just to make sure and my car still turns over but will not start on my safc it goes up to like 100 rpms but wont start
could this possibly be it?
when i had my cams at tdc i accidently left the little pin holders in there holding the cams still and then i tried to turn my lower part with the 19 and the belt kept overlaping so then i realized and took that off could that have messed anything up?
or would i have to take the bottum plastic off because where my cams were at tdc the bottum may not have been?
is it possible that i threw my timing belt off so many teeth? and that is the reason?
Old Sep 11, 2004 | 04:35 AM
honura's Avatar
honura
Seni
Check the timing.
Old Sep 11, 2004 | 06:54 AM
ISP James's Avatar
ISP James
DAMIMRED
check for spark... take one of the plugs out, leave it plugged into the wire.... lay it across the ground on the front from the head to the firewall.... have somebody crank it. no spark is my best guess, thats what happened to me.... if thats the case, its an easy fix, puttin a new dist on will take you about 15 minutes
ISP James's Avatar
ISP James
DAMIMRED
oh and this sounds dumb but you wouldnt be the first one to make the mistake.... check double check tripple check your firing order...
