Compatibility
Old Aug 10, 2004 | 12:55 PM
INTG_VTEC's Avatar
INTG_VTEC
Default Compatibility
Does anybody have any info on Honda-Acura tranny compatibility? I just got a 90 Teg LS with a blown auto tranny. Was wondering if a Honda would fit cause i have one. Thanks
Old Aug 10, 2004 | 01:06 PM
kenton's Avatar
kenton
Change sig? Lose [quote]!
I think the only "Honda" transmission that would work would be out of the 99-00 Civic Si. I could be, and probably am wrong, but I'm almost certain that will bolt up to a B18B engine.
Old Aug 10, 2004 | 02:52 PM
ska32198's Avatar
ska32198
sadly a 90 deg doesent use the b18 engines... depends on the honda tranny, tegs and scivies have been really close in devlopment for very long...
Old Aug 12, 2004 | 03:28 PM
5gdxguy's Avatar
5gdxguy
I'm pretty sure the 90 integra comes with a b18a1, unless of course its a gsr, in which case the engine would be a b17 vtec. In either case any b- series transmission would work, including that of the 99-00 si. The problem would be changing from a cable tranny to hydro, in which case the slave and master cylinders would be needed from the civic, along with the VSS i (think). Also if i'm not mistaken the pedal assembly is different. Some one else correct me if i'm wrong
Old Aug 12, 2004 | 03:33 PM
ska32198's Avatar
ska32198
I thought the d-series was on the 90 and it changed to the b-series starting in 91
Old Aug 12, 2004 | 03:37 PM
Snoopy's Avatar
Snoopy
been there done that
first gen tegs (86-89) had the d16a1. second gen tegs (90-93) had the b18. the g2 gsr didnt come out till 92.
Old Aug 12, 2004 | 04:22 PM
Kai's Avatar
Kai
Rotorphile.
The 90-91's use a 130hp version B18A1.
Look at the car in question. Does it have pop-up headlights? That's an 86-89.
Does it have normal "bar" headlights? That's a 90-93.
