New member needs timing belt advice
Old Jul 30, 2004 | 01:38 PM
Redwing's Avatar
Redwing
Default New member needs timing belt advice
I have an 87 Integra with the DOHC 1.6L which has been sitting in my garage for about a year (since the timing belt broke.) I bought a new timing belt for it and have it installed but it doesn't run right. I have the service manual and I'm pretty sure I've done everything correctly.
Do I most likely have bent valves? I called the local dealership and talked to one of the mechanics and he said it's unlikely that any valves bent when it broke, but I don't know if I buy that.
Anyone gone through this?
Thanks in advance, Brian.
Old Jul 30, 2004 | 02:09 PM
GTXgp's Avatar
GTXgp
RB26 Wha?
How is it not running right? What specifically is happening? Rough idle or a noise that you hear? Could be a valve, or it could just be that its not timed right. Give us some more details on what its doing so we can go from there
Adam
Old Aug 12, 2004 | 11:00 AM
Redwing's Avatar
Redwing
It's running rough like it's out of time. It will stay running IF I stay on the gas a little, but if I let off the gas it stalls. I don't hear any clatter. It's REALLY hard to know exactly where #1 TDC is with the crank pulley since the timing marker is on the cover, which has to be OFF to put the belt on.
Old Aug 12, 2004 | 11:11 AM
1funride's Avatar
1funride
99 Integra LS
Just a guess, but if you are using the the same gas that has been in there for a year it could be that. Gas does go bad after amount of time (i.e. sitting in a tank for a year). Try siphoning out the old gas and putting in new gas.
Old Sep 22, 2004 | 08:46 AM
Redwing's Avatar
Redwing
It's not the gas. It may be bad NOW but at the time I was getting these symptoms, it hadn't been setting that long. only for a couple weeks. I'm beginning to think I just don't have the belt in the right position.
