engine swap
Old Jul 28, 2004 | 01:52 PM
dustimus's Avatar
dustimus
Better golfer than you
Default engine swap
Hey guys i just recently had an 01 b18c1 dropped into my 96 GSR. As soon as i got it back i have an engine code of misfire in the 3rd and 4th cylinder. This engine is brand spankin new, 30k miles so i know it isnt the engine. I know 2001 was obd-2b and my 96 was obd-2a. It idles a little rough, runs fine in upper RPMS, and hits VTEC perfectly. Now i have to be at work at 5, so should i be running my car like this, am I going to f**k anything up. My last motor has a brand spankin new 96 distributor on it, i was planning on swapping those.
Old Jul 28, 2004 | 03:12 PM
LT's Avatar
LT
The deer had to die!
OBD-2a =/= OBD-2b
distributors are not the same.
Old Jul 28, 2004 | 11:16 PM
dustimus's Avatar
dustimus
Originally Posted by LT6916
OBD-2a =/= OBD-2b
I thought so, i plan on swapping them tomorow, think that will fix the idle problem and the "misfire".
Old Jul 29, 2004 | 12:02 PM
dustimus's Avatar
dustimus
also would like to add that my tach doesn't work
Old Jul 29, 2004 | 02:40 PM
LT's Avatar
LT
at all? check ignition coil (distributor related)
Old Jul 30, 2004 | 02:23 PM
dustimus's Avatar
dustimus
replaced the dissy and wires today. Still have the rough idle, CEL codes, and tach still doesn't work.
