Compression test results
Old Aug 10, 2002 | 11:42 AM
CJS's Avatar
CJS
Default Compression test results
Me and my buddy just got finished doing a compression test on my 95 gsr with 104k on it. Cylinder 1 was 202, #2 was 206, #3 was 202 and #4 was 205. We dident disable the fuel system or block the throttle wide open like some manuals say, does this stuff really matter? We dident know how many times to crank it so we cranked it 12 or 13 times per cylinder, is that allright? The number went up fast on each cylinder then leveled out around 200 but was still going up slowly right before we stopped, should we of kept cranking until the number compleatly stopped going up all together?
Old Aug 10, 2002 | 12:50 PM
pomansouth's Avatar
pomansouth
nope supposed to crank 5 times and also take out the fuel pump fuse and you are rdy to go
Old Aug 10, 2002 | 01:31 PM
dubcac's Avatar
dubcac
I
Take out the ECU fuse. While cranking, stand on the gas pedal to hold it at WOT. YOU MUST DO THESE FOR ACCURATE RESULTS
Old Aug 10, 2002 | 01:38 PM
CJS's Avatar
CJS
If I did these two things would I have got higher or lower numbers? And how are the numbers that I got?
Old Aug 10, 2002 | 08:25 PM
qtiger's Avatar
qtiger
Numbers you got are good.
Old Aug 11, 2002 | 04:20 AM
CJS's Avatar
CJS
Who thinks my numbers are good enough to supercharge on?
Old Aug 11, 2002 | 05:31 AM
pomansouth's Avatar
pomansouth
well you need to do a test correctly because that way you really know what the test reads instead of something that might be inaccurate
Old Aug 11, 2002 | 10:41 AM
dubcac's Avatar
dubcac
I
Dude, you have to redo the test correctly before we can assess the condition of your motor.
menappi
CRX & Pre 92 Civic
14
Sep 24, 2003 07:47 PM
justjoe
5
Aug 12, 2003 06:09 AM
h0other
2
Jul 5, 2003 02:59 PM
T-RO
Engine Swaps, Tech & Tuning
6
May 2, 2003 09:01 AM
