VTEC and high flow cat
Old May 30, 2004 | 08:41 PM
neeman77's Avatar
neeman77
Default VTEC and high flow cat
Hey I recently bought an integra GS-R and I don't really know taht much yet about mods. I was thinking about getting a high flow cat but I have a 98 GS-R with the OBD-II ecu. If I were to get a high flow cat, would the second o2 sensor give me a check engine sign? Should I switch to OBD-I?
Old May 31, 2004 | 07:09 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Switching to OBD1 is only really necessary if you have some serious engine mods. Plus it will most likely make you fail an emissions test because in the majority of states OBD2 vehicles are tested by scanning the ECU for fault codes.
On a relatively new car without a modified engine, a high flow cat might free up a few ponies but I wouldn't expect too much. Generally the more common things to do are an intake, header and exhaust. You can add a high flow cat to the mix and it might be a bit of an improvement, but mainly people run them if their stock cat is toast or they need to run much-larger-than-stock exhaust piping which would make the stock cat a big restriction.
As for a CEL, as long as the cat has bungs for both o2 sensors you should be fine.
Old May 31, 2004 | 03:44 PM
neeman77's Avatar
neeman77
ok I live in Canada so i dont really do any emmisions testing anyway. I was planning on doin the basics i/h/e but i just wanted to know about that catalytic. thnx for the reply.
SunsetLude
Prelude
30
Aug 20, 2004 02:20 PM
93si4ws
Dec 21, 2003 10:14 AM
TaylorC01
92+ Civic/EL & Del Sol
40
Sep 1, 2003 11:28 AM
manolis
Engine Swaps, Tech & Tuning
Jul 8, 2003 02:13 PM
pinoyboi
2
Nov 19, 2002 03:34 PM
