Check Engine Light
Old May 21, 2004 | 12:03 PM
sandman65's Avatar
sandman65
Default Check Engine Light
Recently had a bad missfiring problem, lack of power at low rev's. pinned it down to a bad spark to one cylinder. Replaced ignition wires and spark plugs and engine is back to full health, however... the engine check light has stayed on.
This came on when the car started missfiring and from what I have read the missfiring might have effected the 02 sensor and hence the light coming on.
Now with my missfring problem solved, is there any way to get the engine check light off.....
Any help you lot could give me would be greatly appreciated.
Thanks in advance....
Paul...
Old May 21, 2004 | 12:29 PM
carta79's Avatar
carta79
Life after death
What year is your Integra? If you have a third generation Integra, locate your fusebox and pull out these two fuses for a couple of minutes.
Note, pulling these fuses will trip your radio settings. If you have the stock radio make sure you have the pass code to the radio. Place the fuses in the correct slots.
Old May 21, 2004 | 08:41 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
All you have to do is pull the fuse in the underhood fuse box marked BACK UP for 15 seconds. Or if you don't have a fuse puller handy you can just disconnect the battery.
If after you do this the CEL comes back on, you can check the code with this procedure: http://www.c-speedracing.com/faq/06.php
chrisdav6
Accord
5
Jun 18, 2006 06:48 PM
Nikos
92+ Civic/EL & Del Sol
35
Sep 22, 2004 06:23 PM
CRXDOHCVTEC
CRX & Pre 92 Civic
7
Nov 21, 2003 05:24 PM
Chrysalis
9
May 30, 2003 08:12 PM
