Aiming foglights?
Old May 9, 2004 | 11:52 AM
99IntegraGS's Avatar
99IntegraGS
Default Aiming foglights?
According to the installation instructions of the OEM Acura foglights I recently installed you are to check state guidelines for info on how to properly aim your new lights.
I live in Florida. I can find nothing anywhere online that tells me what the FL guidelines for aiming these are.
Any suggestions?
Thanks,
JD
Old May 11, 2004 | 08:52 PM
95tegRS's Avatar
95tegRS
lol, aim them nice and low, (the true purpose of foglights), I doubt there are state guide lines!!
Old May 11, 2004 | 08:54 PM
99IntegraGS
Actually, there are...
FL 316.233 Spot lamps and auxiliary lamps.--
(1) SPOT LAMPS.--Any motor vehicle may be equipped with not to exceed two spot lamps and every lighted spot lamp shall be so aimed and used that no part of the high intensity portion of the beam will strike the windshield, or any windows, mirror, or occupant of another vehicle in use.
(2) FOG LAMPS.--Any motor vehicle may be equipped with not to exceed two fog lamps mounted on the front at a height not less than 12 inches nor more than 30 inches above the level surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of the high intensity portion of the light to the left of the center of the vehicle shall at a distance of 25 feet ahead project higher than a level of 4 inches below the level of the center of the lamp from which it comes. Lighted fog lamps meeting the above requirements may be used with lower headlamp beams as specified in s. 316.237(1)(b).
(3) AUXILIARY PASSING LAMPS.--Any motor vehicle may be equipped with not to exceed two auxiliary passing lamps mounted on the front at a height not less than 24 inches nor more than 42 inches above the level surface upon which the vehicle stands. The provisions of s. 316.237 shall apply to any combination of headlamps and auxiliary passing lamps.
(4) AUXILIARY DRIVING LAMPS.--Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height not less than 16 inches nor more than 42 inches above the level surface upon which the vehicle stands. The provisions of s. 316.237 shall apply to any combination of headlamps and auxiliary driving lamps.
(5) VIOLATIONS.--A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
winston0064
Mar 11, 2004 11:36 PM
AccordCoup94
Accord
Jun 30, 2003 08:00 PM
Illusion-Lighting
Dec 16, 2002 08:14 PM
SeeCamGo
92+ Civic/EL & Del Sol
8
Oct 20, 2002 06:18 PM
ashleylover1123
Accord
7
Sep 1, 2002 09:15 PM
