How much WHP will i have with this setup??
Make me an offer
well when i got my jdm 4-1 header the collector was 2.5inch so i needed a testpipe/cat that was 2.5 inch, i shortened the bpipe and i have just the 2.25 greddy evo piping the apexi n1 rear muffler, i posted many times about this and nobody said anything, am i loosing power? with the cams i get should i upgrade the piping to 2.5?
Get a quality 2.5" catback, so you can unplug your exhaust system
Go 3in. Port the head to free up all the extra air your getting also. If you have that much air the 3in will help. Get a Fuel preassure reg. Sell the fuel rail. It is only heating up your fuel right now. You have no need for it on a return system untill you are dumping major fuel ie bigger injectors higher fuel preassure. Make sure you can control the engine torqueing also. Motor mounts or inserts.
but what does everyone else do when they get a jdm 2.5 collector? they all get the 2.5 "cat but they dont all get a 2.5 exhaust. Its not like i can get a 2.25 inch cat to fit my exhaust cuz i have a 2.5 collector
Make me an offer
Don't go to 3" unless you plan on going serious FI. Otherwise its overkill and it will slaughter your low and midrange. How large your exhaust diameter should be determined by how much hp your engine is generating.
People normally get a 2.5" testpipe, or a 2.5" highflow cat when they get a 2.5" collector.
2-1/2" up to 265HP @ the flywheel (about 225-235 whp)
2-3/4" up to 325HP @ the flywheel (about 275-285 whp)
3" big for big HP (Forced Induction: > 275 whp)
igo4bmx
92+ Civic/EL & Del Sol
3
08-30-2005 07:16 AM
stangkiller
9
05-15-2003 07:07 PM
