Abs
Old Apr 4, 2004 | 04:05 PM
Racter's Avatar
Racter
Default Abs
ok well my abs light has been on since i got the car lol... 2 months ago about now.
well im just now getting to it in the stuff im fixing and i need to know if there is any way to check the code to the abs. i dont know much about abs but when i turn my car on i hear this rattling nosies almost like a rattle snake lol comeing from this umm object i guess that is infront of the abs motor relay(right infront of the passanger headlight). is this apart of my abs???
95 Integra GSR
Old Apr 4, 2004 | 10:39 PM
Born To Lose's Avatar
Born To Lose
there should be a little green plug with two connectors inder the glove compartment. connect the two plugs with a paper clip or something. then turn on the ignition to check the ABS codes. The noise you hear is probably the ABS accumilator trying to repressurize the system. The seal on the accumilator is probably bad. Its the little gold cylinder thind behind the passenger headlight. i hope this helps.
Old Apr 5, 2004 | 07:06 AM
ISP James's Avatar
ISP James
DAMIMRED
im gonna diagnose mine today too.... it has been off for a while but then it fawkin snows last nite :madfawk: and the damn thing came back on.... i hate central NY 8 months of snow 1 month of rain and 3 months that are okay
Old Apr 5, 2004 | 07:18 AM
ISP James's Avatar
ISP James
DAMIMRED
okay i just had to get my car outta my moms way... while i was out there i looked for that little green plug.... no luck. does anybody have a pic of it so i know what im looking for? or maybe more specificly where under the glove box it is?
thanks
Old Apr 5, 2004 | 09:49 AM
Racter's Avatar
Racter
ok that is under the kick panel where the ECU is as im told but i found mine right under the glovebox its a rubber green hold there holds 2 blue plugs.
is one for the CEL digonostics and the other for the ABS digonostics?
Old Apr 7, 2004 | 09:43 AM
Racter's Avatar
Racter
umm anyone know anything? hehe need some help read above post
Old Apr 7, 2004 | 07:27 PM
timmy8151's Avatar
timmy8151
Jump the connector that has the Brown and black wires. You use the same service connector for the ABS and ECU/ECM.
Old Apr 7, 2004 | 08:22 PM
Born To Lose
jump the one with only two connectors
Old Apr 10, 2004 | 01:58 AM
IntegraR's Avatar
IntegraR
Description and Operation
PURPOSE
The ABS indicator light is used to indicate a problem with the ABS system.
OPERATION
This warning system turns on the ABS indicator light when one or more of the following abnormalities is detected. This is only a partial list.
When the operating time of the motor in the power unit exceeds the specified period.
When vehicle running time exceeds 30 seconds without releasing the parking brake lever.
When one of the rear wheels is locked during running.
When absence of speed signals from any of the four wheel sensors is detected.
When the activation time of all solenoids exceeds a given time or an open or short circuit is detected in the solenoid system.
When solenoid output is not detected in the simulated anti-lock brake system operation carried out during running at speeds of 6 mph (10 km/h) or more.
To check the ABS indicator light bulb, the light is activated when the ignition switch is turned on. It is turned off after the engine is started if there is no abnormality in the system.
Temporary Driving Conditions
The anti-lock warning lamp will come on and control unit will store problems in memory under the following conditions:
Problem code 5, 5-4 and 5-8, tire adhesion lost due to excessive cornering speed.
Problem code 4-1, 4-2, 4-4 and 4-8, vehicle loses traction when starting from a stuck condition.
Problem code 2, 2-1 parking brake is applied for more than 30 seconds while vehicle is being driven.
Vehicle is driven over extremely rough roads.
If anti-lock warning lamp goes off after engine is turned off, than back on, ABS is operating normally.
Diagnostic Connector - ABS Locations
Below Front Passenger's Seat
New relay is $38
Warning Lamp Circuit
If anti-lock warning light does not go on when ignition is turned on, check the following items:
Blown anti-lock warning bulb.
Open circuit between No. 15 fuse and warning lamp.
Open circuit in blue/red lead between combination meter and control unit.
Bad control unit to body ground.
If not loose or disconnected, install new control unit and recheck.
If anti-lock brake warning light remains on after engine is started and LED on control unit does not blink any code or sub code, check for the following:
Loose or poor connection of wire harness at control unit.
Faulty ABS 2 fuse.
Open circuit in white lead between ABS 2 fuse and control unit.
Open circuit in yellow/black lead between fail-safe relay and fuse No.17.
Short circuit in blue/red lead between combination meter and control unit.
Open circuit in white/blue lead between alternator and control unit.
If warning lamp remains on while engine is running, proceed as follows:
Stop engine, then turn ignition switch to On position and ensure anti-lock warning lamp comes on.
Restart engine and check warning lamp. If warning lamp goes off, there is no malfunction.
If warning lamp remains on, stop engine, then open trunk or, if equipped, ABS maintenance lid.
Turn ignition switch to On position but do not start engine.
Record blinking frequency of LED on control unit, Figs. 5 and 6. Read trouble codes.
Control unit can indicate up to three trouble codes. If LED does not light, repeat steps 1 through 3.
If required, turn ignition switch off, then turn on to read LED.
After repair is completed, disconnect ABS B2 fuse for three seconds to erase control unit memory, then turn ignition switch on to recheck.
Memory is erased if connector is disconnected from control unit or control unit is removed from body.
File Type: gif
File Type: gif
Old Apr 12, 2004 | 07:36 AM
Racter's Avatar
Racter
... great knowing the idiots that had my car before me theyprobly pulled the e break alot... while they where driving. well thanks for your input it helps i guess.
