Burning oil
Old Apr 1, 2004 | 04:23 PM
itr341's Avatar
itr341
Default Burning oil
Is it common for Type Rs to burn oil? I have 60,000 miles and use 93 octane gas and mobil 1, but I still see a cloud of smoke sometimes in high rpm. Has anyone else noticed this, if so are there any solutions? Thanks.
Old Apr 1, 2004 | 04:45 PM
Padawan's Avatar
Padawan
Future Jedi
The cloud of smoke you're seeing might just be a sign of a rich condition, but my car did go through roughly 1 quart every 1500 miles or so, especially if it was driven "spiritedly".
Old Apr 1, 2004 | 06:32 PM
TopEndBlitz's Avatar
TopEndBlitz
i used about the same amount of mobil 1 in mine also, i switch to castrol and a little thicker weight(10W40) and it was fine
Old Apr 1, 2004 | 07:41 PM
itr341's Avatar
itr341
Thanks, I'll try the switch. I dont like having to clean black soot off my rear bumper every time i wash it!
Old Apr 1, 2004 | 09:05 PM
Padawan's Avatar
Padawan
Future Jedi
I was always under the impression that the soot on the bumper was caused by a rich condition, not necessarily oil burning - perhaps someone else can comment here?
I'm also not sure I'd be comfortable running a heavier oil in an engine such as the C5, though I know some do. You might want to first try switching to a conventional oil, as some people have reported that this aleviates much of their burning problems (it's also been my observation that people report more burning problems with Mobil 1, even compared with other synthetics). You never mentioned if you are actually experiencing oil loss between changes. Is your level normally low at oil change time or when you periodically check it?
Old Apr 1, 2004 | 10:24 PM
DC2fanboy's Avatar
DC2fanboy
I believe almost all R's run rich (stockish) I have yet to see a CW R without the soot on the rear bumper...
I had experienced some M1 burning, less than the described 1 quart top up usually between oil changes but there nevertheless... However, after moving to a "full (real) synthetic" (AMSOil) I have not had oil consumption problems since. And this was with repeated ripping sessions...
Old Apr 2, 2004 | 05:09 AM
George Knighton's Avatar
George Knighton
For whatever reason, Web boards are full of stories of Mobil One burning in ITR motors.
There's so much evidence floating around that many of us have decided to simply never use Mobil One.
I've never really been a fan of any synthetic oil, partially because of Ichisima's famous comments on the matter, which comments he's stood by and clarified in public and emails.
I won't say outright that it's a waste of money, but if you're changing your oil every couple of thousand miles anyway, it does make one wonder.
Old Apr 2, 2004 | 05:41 AM
r1zen's Avatar
r1zen
I had a big burning problem with Mobil1 on my GSR. There is definately a trend here...
I currently run Castrol Syntec 5w30 on my ITR and it works wonders. I change my oil every 3k (all highway)
I'm constantly passing cars and ripping through the gears. I only loose a small amount of oil every 3k.
Old Apr 2, 2004 | 11:08 AM
Asahi's Avatar
Asahi
Administrator
Same Mobil 1 burn problem in all my integras. I use amsoil now.
Black soot on the rear bumper is more likely running rich than burning oil and is very common.
Old Apr 2, 2004 | 02:22 PM
01usjdmr's Avatar
01usjdmr
I too have been using mobil one and the car uses oil at high rpms I plan to change oils soon.
