No Turn Signal or Hazard Lights
Old Apr 1, 2004 | 04:13 AM
Q2Ggirl's Avatar
Q2Ggirl
Default No Turn Signal or Hazard Lights
Yesterday while I was driving home, all of a sudden, both my turning signals (both sides) and hazard lights stopped working.
What type of electrical problem does that indicate since I checked all of the fuses and they were all good?
This is a '97 Integra.
Old Apr 1, 2004 | 08:09 AM
kfar09's Avatar
kfar09
you probably blew a fuse
Old Apr 1, 2004 | 08:32 AM
Q2Ggirl's Avatar
Q2Ggirl
If you read what I wrote the first time, ALL of the fuses were GOOD.
Old Apr 1, 2004 | 09:04 AM
reno96teg's Avatar
ahem.. did you check the fuse/relay box under the hood?
check fuse number 43, i think (it'll be labeled). it's probably blown. if it is blown, you replace the fuse, and it blows again, you probably have a short somewhere.
let us know.
Old Apr 1, 2004 | 11:27 AM
Singhg83's Avatar
Singhg83
BALLIN'
let us know.
i had same problem once, just changed the fuse under the hood and it workd fine
Old Apr 1, 2004 | 11:58 AM
Q2Ggirl's Avatar
Q2Ggirl
I checked ALL fuses. The ones inside the car under the driver's side as well as the ones under the hood. That's what I meant by all. Sorry if that wasn't clear.
Any other suggestions?
Old Apr 1, 2004 | 12:18 PM
00 Celica GTS's Avatar
00 Celica GTS
I am having the same problem right now. Mine started last night. I have checked all the fuses also and nothing. So I also would like to know.
Old Apr 1, 2004 | 12:32 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
This may sound stupid, but do you have a friend that could let you swap hazard light switches with? Might as well eliminate that as the cause if you can. The switch could have gone bad... oddly enough. :dunno:
Old Apr 1, 2004 | 12:35 PM
00 Celica GTS
But if the blinkers do not even work, then it has nothing to do with the hazard switch.
Old Apr 1, 2004 | 12:41 PM
westcoaststyle
You'd be surprised what all runs through that switch. :goodjob:
