No Turn Signal or Hazard Lights
Old Apr 1, 2004 | 12:58 PM
00 Celica GTS's Avatar
00 Celica GTS
Well I am not sure, but I have the same problem but my hazards work, so I know it is not my switch
Old Apr 1, 2004 | 01:28 PM
integranation's Avatar
integranation
slowly catching up...
When I took out my hazard switch while installing my Nav unit I noticed that my blinkers wouldn't work without the hazard switch plugged in. My guess would be the switch if you have checked everything else.
Old Apr 1, 2004 | 01:35 PM
reno96teg's Avatar
Originally Posted by 00 Celica GTS
But if the blinkers do not even work, then it has nothing to do with the hazard switch.
they're on the same fuses, aren't they? not saying that her problem is indeed the hazard switch, but it's not impossible.
Old Apr 1, 2004 | 08:40 PM
ls_101's Avatar
ls_101
integra fs
its either the turn signal switch or the relay because the turn and hazards are wired together
Old Apr 2, 2004 | 12:52 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
It could be a lot of things, BTW the whole circuit runs in series with the hazard switch, if the hazard switch is unplugged or defective you have a open in the circuit and then nothing will work as far as turn signals. pull out the connector from the hazard switch and jump it will a paper clip, then check the lights.
Old Apr 7, 2004 | 12:32 PM
Q2Ggirl's Avatar
Q2Ggirl
Default Solution!!!
It was the relay switch. Thanks for all of the suggestions. I'm back in bidness now....
SolReavr
92+ Civic/EL & Del Sol
19
Feb 23, 2004 11:09 PM
yankee81116
Prelude
5
Feb 12, 2004 03:33 PM
gAmEs0n
Sep 17, 2003 08:10 AM
Rawbeef
Accord
3
Jul 27, 2003 06:10 PM
ElectronBlueGSR
12
Jun 21, 2002 07:58 AM
