Replace main relay
Old Mar 30, 2004 | 02:14 AM
maldini's Avatar
maldini
Default Replace main relay
I am thinking of buying the mainrelay and then taking it to the mechanic to be replaced. Is it going to be easy for the average mechanic to replace the main relay? Do they do this often?
Old Mar 30, 2004 | 04:01 AM
g2tegls's Avatar
g2tegls
MR, ftw
It should take a novice about 15 minutes with a single wrench. It should take a pro maybe 5 minutes.
Old Mar 30, 2004 | 06:14 AM
Sam92teg's Avatar
Sam92teg
On my 92RS, it was an easy swap, 2 phillips screws to remove the driver's side kick panel and the relay is right behind it. Better to take 10 minutes in your driveway than to take longer going to the mechanic. Good luck.
Old Mar 31, 2004 | 01:43 AM
maldini's Avatar
maldini
The main relay just snaps in place? There is no wires to connect? If that's the case, then good. Thanks.
Old Mar 31, 2004 | 03:52 AM
g2tegls's Avatar
g2tegls
MR, ftw
It's held in by a single bolt, if i remember correctly, and you have to detatch a small wire harness from it. That about sums it up.
Old Apr 5, 2004 | 01:23 AM
maldini's Avatar
maldini
Do you need to detach the battery first before replacing the main relay?
Old Apr 5, 2004 | 08:10 AM
Spec R's Avatar
Spec R
its best to do so with any kind of electrical related work. so, yes, disconnect the negative terminal of the battery.
DB Squad
Integra Forum Moderator
Old Apr 6, 2004 | 08:38 AM
AP2's Avatar
AP2
Moderator Alumni
It's not a big deal, you don't have to disconnect the - terminal. I had to change my relay quite a few times to diagnose a certain problem. You just need a 10mm to get it off the bracket and some fingernails to unclip it.
Kaspin
Do It Yourself
21
Feb 9, 2010 08:46 PM
5spdLegend
Accord
8
Feb 3, 2005 05:49 PM
RotaryPower88
2
Dec 29, 2003 02:56 PM
rodb
Accord
3
Sep 17, 2003 09:53 AM
Konga Man
CRX & Pre 92 Civic
2
Jul 6, 2002 04:57 AM
