Difference between a 215 and a 205 Azenis tire?
Guest
Posts: n/a
Originally Posted by Zorro
I was thinking of running a set of 215 Azenis for some extra grip this year. I read in one of the topics here that a 215 Azenis is only .1 inches wider then a 205 Azenis. Is this true?
To be perfectly honest, there was very little difference in height between the two stacks.
My personal inclination, after having owned the ITR since Dec 1999 and having gone through a lot of tyres and wheels, is that I would stick w/the cheap 15x7 wheels and cheap 205 Azenis.
That's just me, though.
Guest
Posts: n/a
Yes… I am comparing the 205/50/15 to the 215/45/16
My goal is to run in the NASA time trail events this year. I do not want the point penalty of running R compounds and I do not have the $$$ to run R compounds.
I need a DOT tire that has a tread wear above 80
[quote:fa34a52ac7]I understand that an 8 inch wide rim running a 215 tire will not bind as much as an 6 inch rim running a 205, but if the 215 is not going to give me an improvement on handling then why run it. That is what I wan to know.[/quote:fa34a52ac7]
Is it possible for you to look into a different choice of rim? Maybe something that fits the 205 Azenis better than your 15x6.
( 15x7 seems to be very popular ).
